587,560 active members*
3,536 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How to bypass spindle external encoder for okuma lathe osp controller
    Hi Friends ,
    Any one can help me with the spindle bypass parameter for okuma lathe osp controller “Er-Ma-Sa “
    Please have a look at the attachments
    Aug 2019
    339
    Re: How to bypass spindle external encoder for okuma lathe osp controller
    Set the control's param "use encoder" to Bit 0 for the spindle axis. Whatever param<name> that is, most controls have one of those
    Quote Originally Posted by Mecanix View Post
    Mecanix, Thanks for your reply ..let me check .
    Will be more helpful if you could give me the parameter number ????
  1. Replies: 7
    Last Post: 07-20-2022, 09:12 PM
  2. spindle encoder for lathe
    By anowrosh in forum Mini Lathe
    Last Post: 02-11-2018, 11:03 PM
  3. spindle dc servo / encoder, lathe
    By hutchison in forum Machines running Mach Software
    Last Post: 04-05-2009, 03:48 PM
  4. Need an encoder for my C3 lathe spindle.
    By alexccmeister in forum Shopmaster/Shoptask
    Last Post: 08-07-2008, 04:56 AM
  5. 2-1/2 External NPT on Okuma Lathe
    By jdr1961 in forum G-Code Programing
    Last Post: 02-15-2007, 04:12 AM
