587,158 active members*
2,873 visitors online*
Thread: Hoss's G0704
Page 343 of 344 243293333341342343344
Results 6,841 to 6,860 of 6871
  1. #6841
    35538
    Re: Hoss's G0704 - Anyone heard from Hoss lately?
    Quote Originally Posted by MiniSoCalCNC View Post
    Concerned ... somethings up - His domain expired 12/6/17 ...
    This site is still up.
    g0704.com
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  2. #6842
    Anyone heard from Hoss ?
    He's fine, busy gettin healthy. Working on combining the websites for convenience is all.
    Hossmachine Store
    Hoss
  3. #6843
    Sep 2017
    53
    Quote Originally Posted by hoss2006 View Post
    Hossmachine Store
    Hoss
    Excellent news ... gave a brother a bit of a fright :-) Glad all is well - Merry Christmas / Happy Holidays my good man.
    Thanks for the update ...
    while we're here :-) got any links on any of your sites or others indicating how I can finish wiring this C11G BoB to a Solid State relay to control coolant 110v power plug? Ive seeming looked everywhere and was headed over to Hossmachine for some possible links and discovered it was - down ...
  4. #6844
    Nov 2009
    4415
    Do you have the load connected to the relay?
    Many SSR’s wont light up unless the load is connected. They use parasitic voltage from the wiring.
    Sent from my iPhone using Tapatalk Pro
    A lazy man does it twice.
  5. #6845
    Jan 2018
    12
    Re: Hoss's G0704 - C3 board, mach 3 not seeing rpm
    Can anyone tell me what the screw size for the Y-axis mount on the G0704 is? I need to buy some longer screws for my stepper mount and I thought I had the right ones, but I do not.
  6. #6846
    Sep 2011
    281
    Quote Originally Posted by kies277 View Post
    if 1/4-20 doesn't work, try 8mm if I'm not mistaken. you can also re-tap to 1/4-20. this is what I did on my KC20-vs from King Industrial in Canada. made it easier than attempting to figure out the metric bolts on my mill which is a clone of the grizzly, but metric.
    Colten Edwards http://www.cncsigns.ca
  7. #6847
    Apr 2016
    100
    Quote Originally Posted by cd_edwards View Post
    I was reluctant to answer this because I didn't know which screws to talk about. The 704 itself is metric, tapped 6.0 x 1.0 mm, but that's not a motor mount, that's the extension that leadscrew goes through. The phase 3 motor mounts that are made from angle aluminum are tapped 8-32 on one end and 10-32 on the other. But the phase one and phase two mounts that are tapped, 1/2" aluminum bar are 10-32.
    So the answer to what screw size is "which screw?"
    CNC hobbyist since 2003.
    Current CNC hardware: Sherline/A2ZCNC extended, 4 axis X/Y mill and Sherline lathe
  8. #6848
    Jan 2018
    12
    I found it, they are M6. Thank you all for the help. Anyone know why my stepper motors are running dreadfully slow? I just got them hooked up through Mach 4 with an ESS board. I have a NEMA 34 and 2 NEMA 23's. I have the controllers set to 1600 pulse.
  9. #6849
    Feb 2010
    3447
    Hossmachine Store
    Hoss
    Hoss, tried to shoot you an email and it got returned. Hope all is well.
    Sent from my SM-N910V using Tapatalk
  10. #6850
    Re: Hoss's G0704
    [email protected] is back up and running now.
    Hoss
  11. #6851
    Feb 2010
    3447
    Re: Hoss's G0704
    Hoss
    Good to hear from ya! I'll get around to shooting you an email this week! Hope your making some chips!
  12. #6852
    Jan 2018
    12
    Re: Hoss's G0704
    I am trying to get my Z axis dialed in and am having a problem. I had it at 1600 pulses/rev and got it moving the correct distance, but the problem is when i make small adjustments it moves .015 instead of .010 (and .007 instead of .005). So I can move it 6 inches up and it will be right on, but if I am at the work piece doing thousandths of inches, it is going 1.5X the amount I want. I tried on other pulses/rev settings also, from 800 up to 8000 and they all do 1.5X. I am using a smooth stepper and the KL8070D with a Nema 34 and the Ebay Z axis double ball screw. The X and Y work fine at 1600.
  13. #6853
    Jan 2014
    17
    I'm not sure where your getting your steps per inch or steps per revolution information, or what specific motors controllers you have.
    What you need to know is, first your stepper motors number of steps per revolution. Example, my nema 34 960oz motor has 200 steps per revolution.
    2nd, you need to know how many microsteps your stepper driver is set to deliver. Example, my geckodrive g201x is set for 10 microsteps.
    3rd, you need to know the pitch of your ballscrew. Example, mine is a 5mm pitch.
    Now, for my setup. My mach3 native units are set for "inches". A little math: 25.4mm per inch divided by 5mm ballscrew pitch gives a ballscrew travel of 5.08 revolutions per inch.
    So, 200 stepper motor steps per revolution, multiplied times 10 stepper driver microsteps, multiplied times 5.08 ballscrew revolutions per inch gives me a mach3 "steps per" (that's steps per inch when Mach 3 native units is set for inches) setting of 10160 (Mach 3 will interpret a microstep as a step).
    10160 microsteps from the stepper driver = 1 inch of travel.
    You said you have a 6mm pitch ballscrew. If I assume your native units in mach 3 is set in inches,and your stepper driver also set for 10 microsteps, and you have 200 steps per rev stepper motors, then you would need your mach3 motor tuning "steps per" set to 8166.666666667 "steps per". I doubt a stepper driver can deliver a fractional .6666666667 number of steps. I'd go for a whole number.
    If you set your stepper driver to 12 microsteps, then you'd end up with a nice even whole number "steps per" setting of
    (25.4 / 6) x (12 x 200) = 10160 "steps per"
    My x and y axis stepper drivers are nema23 540oz motors, also 200 steps per revolution, and my x and y ballscrews are also 5mm pitch screws. My x and y stepper drivers are 8 microsteps. So, my x and y are 25.4 / 5 x 200 x 8 = 8128 "steps per"
    It sounds like your "native units" may be set for mm, in which case, your 6mm screw and a 10 microstep driver and a 200 step stepper motor would need a "steps per" setting of 160 steps per mm.
    I hope this helped.
  14. #6854
    Jun 2011
    692
    Re: Hoss's G0704
    Do you have backlash compensation turned on?
  15. #6855
    Apr 2016
    100
    Re: Hoss's G0704
    First off, what Ken226 is saying is exactly right. I use the KL6050 drives that Hoss had in the parts list I bought, but the motors are the most common 200 steps per revolution, my drive is set for 8 microsteps, and the same ballscrews. it works out to 8128 steps per inch. Being a couple of steps different from the calculated value is normal, I think, and you verify that with a dial indicator moving a full inch. That's from small errors in the ballscrew that the Quality Control guys in the business call ballscrew drunkeness. If I recall correctly, all three of my screws are slightly different. What that means, though, is that if you set your table to go exactly one inch in the middle of your table, you might not go exactly 1.000 inch on any other place on your table.
    When I saw this last night, I wondered how you knew it was going 6.000 inches instead of a few thousandths too much. It's not exactly easy to get micrometer accuracy over 6" (without a 6" micrometer). What your post is implying is that your system puts out too many step pulses if you go a short distance but it puts out the right number if you go farther. It really just multiplies steps per inch times the inches you're going and spits them out.
    When I built my Sherline CNC system, it did some odd things, but just extra steps no matter what distance I was moving it, and just moving a couple of steps on its own. That was electrical noise pickup, but what you're talking about sounds different than that.
    Sorry I have nothing more to suggest.
  16. #6856
    Jan 2018
    12
    I am using a dial test indicator to measure. I start it at the table and move it up a known distance(a measured object such as a 1x2x3 block or parallel bar). The backlash is not relevant in this case, I am only moving it one direction. Probably does not help that automation technologies did not send one stitch of paperwork for the motors or stepper drivers.
  17. #6857
    Apr 2016
    100
    Re: Hoss's G0704
    If it goes 50% too far at .005 and .010, does it go 50% too far at 0.050, or 0.100, and so on? That would say you have a steps per inch problem.
    I spent a little time on Automation Technologies and found the data sheets on what you have.
    In particular, your motor driver. According to the picture of the KL8070 set you got, the controller is the KL9082. The data sheet is linked on the web page for that part (toward the bottom).
    https://www.automationtechnologiesin...rivers/kl9082/
    Your NEMA 34 1200 in*oz motors are 200 steps/rev. The data sheet says that you can set it to any one of 16 values for steps per inch: 400, 500, 600, 800, 1000, and up to 10,000 steps per rotation. If you're using a 5.08 turn per inch pitch ballscrew, like the ones in Hoss' plans, I don't see a setting on that motor driver that will give you 1600 steps per inch.
    Do you know what the ballscrew pitch is? You mentioned eBay, but no numbers on the screws.
  18. #6858
    Jan 2018
    12
    The pitch is 5mm
  19. #6859
    Jan 2018
    12
    This is the driver
    The pitch is 5mm
  20. #6860
    Apr 2016
    100
    Re: Hoss's G0704
    This is the driver
    Interesting to see that. AT doesn't have the datasheet for it displayed on the webpage, and searching for KL-8070 only brings up the kit with the pictures of the other driver in it, but they have the datasheet here (web search found it). Still, you can see all the switch settings on the motor itself - the same table is in the spec.
    The 5mm pitch means the 5.08 revolutions per inch that Ken226 said is correct.
    I'm also using 1600 steps per rotation of the motor, times 5.08 rotations per inch or 8128 steps/inch. I took a look at them in Mach3 a little while ago, and the tuned value is 8137, which is 0.1% different than computed. I'm also using an Ethernet Smooth Stepper.
    I've never seen this sort of weird problem, so I'm guessing here, but in my work life I've noticed that when weird things happen, I should check the grounding. I'd say to check the wiring to the motors and make sure both ends of each wire are connected with no loose connections. Likewise look for loose wires or bad connections in your box that's driving the motors. If you run ground wires, check those.
    Also, it's not that's off in only one direction, like only going up or down, right?
    Something this weird sounds like it could be software, but if it's one of the big names, I'd assume it's good.
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
