587,246 active members*
2,902 visitors online*
Thread: Hoss's G0704
Page 284 of 344 184234274282283284285286294334
Results 5,661 to 5,680 of 6871
  1. #5661
    Nov 2013
    39
    Re: Hoss's G0704
    What setting do all y'all use for micro-stepping on the KL23H2100-50-4B stepper motors?
    -Bill
  2. #5662
    Apr 2007
    17
    Re: Hoss's G0704
    Quote Originally Posted by wrljet View Post
    -Bill
    I use the MX3660 and use 1/8 micro step.
  3. #5663
    Re: Hoss's G0704
    -Bill
    1/8 microstepping, it runs smoother.
    Hoss
  4. #5664
    Nov 2013
    39
    Re: Hoss's G0704
    Quote Originally Posted by hoss2006 View Post
    Hoss
    1/8 micro-stepping means 1600 steps/rev?
    Bill
  5. #5665
    Re: Hoss's G0704
    Bill
    Yes, If you are running the C7 ballscrews the pitch is 5.08 so 8128 in steps/per in motor tuning.
    Hoss
  6. #5666
    Re: Hoss's G0704
    I have the mill nearly back together. With the C7 nuts having a lube port in the flange it makes adding the ballscrews to the oiling system easy.
    The port is M6x1 and for my system using 1/8 ID tubing the use of barbed fittings makes it nice.
    The Y axis uses a straight barb, Mcmaster #5058K325, with the nut rotated 22.5 degrees from normal allows it to come straight out of the top.
    The X axis uses a 90 degree barb, Mcmaster #5047K142, though it's threads are 1/4-28 they are close enough to m6x1 that it screws into the port without too much persuasion, being acetal helps.
    A 3/8 inch slot machined into the saddle provides clearance for the fitting.
    The barb holds very well, I had to cut the tubing so I could pull it apart the first time I tried it.
    If you heat up the tubing you can bend it at an angle and it will hold that shape when cool.
    Hoss
  7. #5667
    Re: Hoss's G0704
    On a similar note my old oil pump gave up the ghost so I ordered a more typical hand pump type this time.
    I like this one because of the price, it's located in the US, has a 1 liter capacity ( bigger than most) and maxes at 70 psi.
    1 Liter Bijur Style Manual Lubrication Unit for Bridgeport Mills CKE 8 Oil Pump | eBay
    Hoss
    Attachment 234204
  8. #5668
    Re: Hoss's G0704
    Quote Originally Posted by ihatetyping View Post
    I purchased the dvdrom_super_combo_download this morning.
    Wanted to thank you, Hoss for making this great resource available.
    I plan on placing my G0704 order this Monday with grizzly.com.
    I'm not a machinist so I have a lot of reading, catching up to do on this thread!
    They just now approved your first post here, now that it is visible thank you and hope you have fun learning.
    Hoss
  9. #5669
    Apr 2014
    6
    Re: Hoss's G0704
    Hi Hoss,
    I just purchased your Combo DVD also. Looking forward to receiving it. I haven't done much with my mill since I got it. Been working on buying tools and getting my shop back in shape.
    Speaking of tooling... I'm thinking that since I eventually want to go to the power drawbar that instead of investing in a lot of R8 tool holders, I should probably invest in the Tormach TTS-R8 adapter collet and buy all the other tooling with the 3/4 inch straight shank. (Is there a name for that?) I haven't even put the R8 shank in the drill chuck yet as I was thinking of getting a 3/4 shank for it if that's practical.
    Jody
  10. #5670
    Re: Hoss's G0704
    Quote Originally Posted by JodyCaldwell View Post
    Hi Hoss,
    Jody
    Thank you too!
    If you are heading that way a starter TTS package is a good place to start.
    Starter Set, Manual, Tormach Quick Change - LittleMachineShop.com
    Many buy the ER holders on ebay too from china or darkon that can save some money on sets of 10.
    Hoss
  11. #5671
    Aug 2004
    3215
    Re: Hoss's G0704
    I have not looked but the two stubs on the side seems to be the housing for carbon brushes, which will wear out, If so has anyone looked at them and see if you could find a source for replacements, with the continuous use we would put them to they will wear out allot quicker than in a tread mill.
    Thanks,
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  12. #5672
    Re: Hoss's G0704
    I haven't looked yet but mcmaster has brushes in many sizes including ones that fit the nordic track treadmill motors, bet there will be a size to fit, I'll look.
    Hoss
  13. #5673
    Re: Hoss's G0704
    Mcmaster.com #65705K24 is for a pair of brushes that look like they'd fit if the spring is cut shorter but @$18.19 you could almost buy another motor/controller.
    Especially since as pat commented on my video, use BIG40 as the coupon code and you get the motor/controller for $22.
    Hoss
    Attached Thumbnails Attached Thumbnails 100_5430_800x600.jpg   100_5431_800x600.jpg
  14. #5674
    Nov 2010
    2
    Re: Hoss's G0704
    Hi Hoss,
    Jody
    Thanks for asking that question Jody....now I don't have to. :cheers:
    I wanted to ask you Hoss what kind of vise for the mill do I need to buy and where would you recommend getting it from. I'm planning on purchasing the horizontal/vertical rotary table you list in the DVD very soon. Thanks
  15. #5675
    Jan 2014
    4
    Re: Hoss's G0704
    Hoss,
    How is the double ball-nut testing? I'm curious if you have loss of travel as a result, or if you're still ahead of the game with some of the mods you've done (Y extension, flipped Z column). I have been frustrated with lack of stock Y travel lately. I'm interested in doing the extension along with putting the Y ballnut through the back of the column for a rear stepper mount. I assume this also requires a longer Y ballscrew?
    Thanks for all the great info.
  16. #5676
    Re: Hoss's G0704
    There are several links on my main page under accessories, 4 inch vises are good for the stock mill, 5 for the extended travel version.
    Can't go wrong with the Glacern but the cheap ones will do the job though might be off a thou or two.
    Hoss
  17. #5677
    Re: Hoss's G0704
    Quote Originally Posted by adam3999 View Post
    Hoss,
    No loss with the X travel, the Y depends.
    For the stock mill you should still get the stock 7 in. travel as there is room for the double ballnut to fit.
    With the extra travel mods I did to the base before I'm getting 8 in. vs 9 in. with the shorter nuts.
    The longer ballnut hits the casting in the same place it would with the stock travel so the casting removed from the top of the base slot in the mod makes no difference.
    You could get more Y travel by milling out more of the casting to allow the nut to come farther forward but that's too much for me to get into now.
    That would also require an inch or so longer ballscrew for the rear y mount.
    My rapid speed is only a little slower than what I was getting before (275 vs 330) but checking backlash will have to wait till I make the new mounts, what I'm using now is a mix of printed parts so I still get .001 on the X and .003 on the Y, all metal parts and new bearings should help but at least it's running again.
    Hoss
  18. #5678
    Apr 2014
    6
    Re: Hoss's G0704
    Hoss,
    Thanks for the recommendation on the TTS starter package from LMS. It was just what I was looking for so I ordered one. I'm also looking for a vice so I'll check your site for that too.
    Jody
    Sent from my SCH-I605 using Tapatalk
  19. #5679
    Re: Hoss's G0704
    Hoss,
    Jody
    You don't have to wait for the power drawbar to take advantage of the TTS for quick changes, I came up with a simple setup that lets you use it manually quickly.
    Projects
    You can use them of course traditionally and manually tighten/loosen the drawbar for greater retention.
    Hoss
    https://www.youtube.com/watch?v=86fWHkJiuSM
  20. #5680
    Nov 2009
    4415
    Re: Hoss's G0704
    Hoss' MAD is damn convenient!
    A lazy man does it twice.
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
