587,865 active members*
2,991 visitors online*
Thread: Hoss's G0704
Page 200 of 344 100150190198199200201202210250300
Results 3,981 to 4,000 of 6871
  1. #3981
    Apr 2005
    419
    Hey, I noticed that your timing belt conversion uses flange-less timing belt pulleys. What prevents the belts from walking off the pulleys?
  2. #3982
    Quote Originally Posted by 691175002 View Post
    Proper alignment.
    Some versions of the belt drive do use flanged pulleys though.
    Hoss
    Ran these flangeless pulleys for many months, up to 6800 rpm, never had a walk-off.
    [ame="http://www.youtube.com/watch?v=BSqYDminUzI"]G0704 Belt Drive RPMs - YouTube[/ame]
  3. #3983
    Dec 2012
    0
    New Mill
    Hi Hoss, thanks for the reply. I checked out the site candcnc.com and it seems mostly about plasma tables. I can dig there a bit and contact them, but just a little confused because not much focus on mills that I could find. Anyhow thanks for the link and I will be checking out the videos to understand the process. My goal is still to buy a kit for this mill, get it running and then get another mill just like it and DIY the second one if possible. If I can't find a decent kit then I may end up with a Tormach or a Smithy mill, and I will DIY the one I have, but not for a while.
    So just to be sure, is a plasma kit the same as a mill kit as far as controllers go? Also, if my mill is close or the same as a BF30, are kits already available out there?
    James
    :cheers:
  4. #3984
    Dec 2009
    1416
    Quote Originally Posted by Titaniumboy View Post
    photomankc,
    Can you elaborate on how and why you lost the 0.8" of Y travel? I was under the impression that the CNC conversion wouldn't lose any X or Y travel.
    Titaniumboy
    Its not the conversion, I just noticed it when I had the column off and was repacking the nuts with larger balls on the X/Y table. Since I don't have limit switches I made marks to show the home positions for X/Y and when I ran the Y back by hand with no column I got well beyond the mark made for the Y home. That mark represented the rear-most travel of the Y before the table runs into the column and the bunched up rubber way cover. If I add 1" of spacer I can get that additional travel and keep the way cover and column from consuming any of the Y travel.
    Now I would swear back in the manual days I had roughly 7" of travel in Y and now I only have about 6.5" but I never noted the travel down in the manual days so I'm not completely certain of what if any difference there is. I don't see any obvious interference beyond the nut mount running into the slot without the column so maybe I never had that much to begin with. Mines a PM-25 though, not a G0704.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  5. #3985
    Nov 2009
    4415
    Quote Originally Posted by Flexo! View Post
    Last time I ordered from Weiss it sounded like they where getting inundated with small orders for parts, so wouldn't be surprised if they start forwarding people to their local agents etc
    The contact on this side of the pond was able to understand and communicate well in English. That carries a few points.
    A lazy man does it twice.
  6. #3986
    Quote Originally Posted by J24 View Post
    James
    :cheers:
    The suitable packages are under Plug and run cnc electronics/ router med-heavy.
    If you can afford a Tormach then by all means get one.
    There are no kits to convert a bf30.
    Hoss
  7. #3987
    The forum gremlins are causing a lot of trouble these days, working again now.
    I got a good deal on a CO2 laser power supply, I think.
    http://www.ebay.com/itm/230850256301...84.m1423.l2649
    Hoss
  8. #3988
    Seeing if posting pics is still working.
    Hoss
    Ok, seems good to go now.
  9. #3989
    Nov 2009
    4415
    Why have I already seen the video of the new Hoss spindle?
  10. #3990
    Huh?
  11. #3991
    Nov 2009
    4415
  12. #3992
    ahh, I posted that video a page back.
    Hoss
  13. #3993
    The laser tube arrived safe and sound.:banana:
    Hoss
  14. #3994
    Jun 2011
    695
    Holy cow that is alot bigger then I envisioned.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  15. #3995
    Quote Originally Posted by FannBlade View Post
    That's what she said.
    It'll fit though I may use mirrors instead of directly mounting it on the mill in an enclosure.
    Hoss
  16. #3996
    May 2005
    2502
    Quote Originally Posted by hoss2006 View Post
    Hoss
    I wonder if the tube will last longer if it isn't exposed to so much vibration because you've used the mirrors?
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  17. #3997
    My thinking too though the enclosure I planned would suspend the tube inside an ally square tube
    with printed supports and rubber shims.
    The only vibration should come from the x and y steppers.
    Hoss
  18. #3998
    Jun 2007
    93
    Hoss, Have you checked out this guys vid for a CNC laser? [ame="http://www.youtube.com/watch?v=pgSefHXlIek"]HERE[/ame] Pretty neat setup all together.
    SFL
  19. #3999
    Pretty cool indeed, can't wait to have fun myself.
    Hoss
  20. #4000
    Jun 2011
    0
    Wink
    Holy Crap you've now taken hobby CNC to a whole new level.....aaaaargh
    Not only have you rewriten the book on 3D printing, the benchtop mill X2, Benchtop Mill G0704, Benchtop Mill 4th axis, Benchtop Mill 5th axis, Benchtop Mill ATC for us who are misserably trying to sift through the vast relams of info you have supplied FREE just to annoy us......and who may I add we cannot even remember yesterday not to mind the flippin website of the so and so who supplies the most outragous thingies who none of us can even remember and not to mind even pronounce the name of the what-ya-may-call-it blastet `thingymajig but in a jifi and out of the blue, you like a magician can pull out of your hat the link to the what-ya-may-call-it thingy and not only can that you have flippin loads of suppliers and can even reccomend the flippin best supplier(nuts)......
    and now you're doing something with some kind of a laser.....
    I give up.....
    Eoin
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
