587,822 active members*
2,925 visitors online*
Page 13 of 72 311121314152363
Results 241 to 260 of 1431
  1. #241
    Feb 2004
    1311
    outsider787, I don't think anyone here has completed their H-1 yet. I have a thread going on my build now. I am actually writing the assembly manual for SeeMeCNC H-1. The mechanicals are done now and I am working on the extruder and electronics.
    As for parts quality, the Yahoo group has lots of photos, etc. Also, there is no reason to think that quality will be any different than similar RepRap machines. They all work on basically the same mechanics (threaded rods and linear rails/drill rod). The H-1 uses 1/4" diameter stock but it is also smaller. The extruder is the basic Steve's Extruder that almost everyone uses. Much of the quality is dictated by setup and tuning the machine. I've seen some very impressive parts from these types of machines and don't think mine will be any worse. Stay tuned!
    cheers,
    Michael
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
  2. #242
    Quote Originally Posted by outsider787 View Post
    So what's the surface finish like on parts made on the H1 from SeeMeCNC?
    Can someone post come closeup pictures please?
    I'm not using an H1, I've built a Reprap Prusa.
    If you are trying to judge the quality of the prints these machines can accomplish,
    asking folks that are just starting to use them is not the best place to go.
    Go to thingiverse.com and look at what's being made.
    Most of the projects include close-up pics and you can see what experienced people can do with them.
    Hoss
  3. #243
    Oct 2008
    1642
    John at SeeMe has been doing some very nice prints in ABS on a stock H1 with no mods. He did add the new nozzle design but his prints were very nice with the old nozzle as well.
    I have both the Mendel and H1 however I built my H1 first and my Medel is almost complete. So here is a long winded reply...
    I started with Mach and using PLA and my prints were turning out very nice, no blobs or holes right out of the box with John's modified Replicator/Skeinforge combo.
    I didn't like the computer and hardware laying all over the place and I really wanted to play with a self contained system so I put a Ramps 1.4 system on my H1. It took a while to get it tuned and calibrated. My PLA prints turned out pretty good but I was getting very small blobs on the outside corners. Probably just a lack of tuning on my part and understanding the software and firmware settings since it wasn't doing it mach.
    Instead of more tuning with PLA I ended up switching to ABS to avoid the plugging problem I was having with PLA. My First two ABS prints turned out okay but surely nothing to brag about and not as nice as the PLA but again, it's just because I don't have it all dialed in.
    I have been jumping back and forth and experimenting but what I plan to do is put the H1 back on Mach, and the Medel on the Ramps and play with one at a time and fine tune.
    The nice thing about Mach is you can see everything real time and you can adjust feed rates and such real time so it's much more flexible.
    The nice thing about the Arduino setups is the printer can be self contained and you can insert an SD card and tell it to print. Makes a much neater setup for limited space areas and much more portable.
    At this point, both have their own set of advantages and I haven't played with either enough to have a favorite.
    Richard
  4. #244
    I'm building the Printrbot next.
    Image of THE Printrbot - Thingiverse
    The minimalist design is very appealing, the less parts the better IMO.
    I'll use the H1 electronics and Mach 3 for the control on it.
    Also want to try that new hinged Wades extruder for it, should be cool.
    Hoss
  5. #245
    Quote Originally Posted by Starnovice View Post
    That looks like fun! My Grand kids would like that. Have you gone through your first reel of plastic yet?
    I've just about used up a 1lb spool of PLA, made a lot of parts (and scrap) from it.
    Any of the clearish looking pieces I've shown like the cube gear was made from it.
    I used a little bit of the black ABS 1lb spool but hardly enough to notice anything missing.
    Got my new power supply in so I'm gonna get into some more ABS printing,
    it seems to make a smoother print, stinks a bit more though.
    Hoss
  6. #246
    Jun 2011
    0
    I really like the look of the Printrbot, I was going to print one when I get my H1 running.
    The other designs I'd like to play with are the Bowden style extruders and the X/Y axis designs that don't move the table, for more compact larger print areas.
    First things first though, still need to wire and tune the H1, won't happen in the next week though, I'm out of town again.
  7. #247
    Oct 2005
    2392
    Quote Originally Posted by hoss2006 View Post
    It's getting bad, I go to the printer first thing when I get up even before turning on the computer now.
    Get it printing something while I'll have my coffee and check email.
    Made a little improvement to the Z axis home switch (they call them endstops)
    It needs tweaking now and again to keep the nozzle height just right above the bed...
    Hoss if you have not already seen it there is a thread on the forum for making electronic home switches;
    http://www.cnczone.com/forums/open_s...made_easy.html
    These would be ideal, as they have no moving parts and very accurate. They are also very easy to make.
  8. #248
    Yes I have thanks, I'll have to consider it. The RAMPS can also use opticals so I'll have
    to check. The Z is all that matters for accuracy on these.
    Hoss
  9. #249
    This will show what I've done with 1lb of PLA.
    Hoss
    [ame="http://www.youtube.com/watch?v=oneL1VQFs6Y&list=UUjoRKEpk7uE5Wzf4b-IFTFg&index=1&feature=plcp"]Reprap Prusa Parts made from 1lb PLA. - YouTube[/ame]
  10. #250
    Oct 2008
    1642
    Hoss, I just got finished wiring up my Mendel. Do you mind sharing your Marlin config or at least let me know what you ended up with for step settings per axis and accel so I have a starting point? If not I understand, just trying to short cut it some.
    Richard
  11. #251
    Quote Originally Posted by rwskinner View Post
    Richard
    Sure, I have it saved as Marlin2. Open "Marlin2.ino" in Arduino.
    Hoss
    Attached Files Attached Files
  12. #252
    Oct 2008
    1642
    Thank you sir, very much appreciated !
    Richard
  13. #253
    Oct 2008
    1642
    Oh, are you running in 1/8 steps or 1/16 steps?
    Richard
  14. #254
    1/16th for all except for 1/8 on the z axis.
    Hoss
  15. #255
    Oct 2008
    1642
    Thanks, it only took a minute to figure it out when everything was twice the distance.
    Two prints under my belt with the Medel using ABS and they turned out very nice indeed right off the bat. No blobs or any issues.
    I think my H1 must have a little backlash causing the small blobs in the corners because I didn't see that here running the same GCode.
    Cool. Things are looking up. Now to get the H1 back on Mach and get it tuned correctly.
    Thanks again,
    Richard
  16. #256
    Apr 2004
    128
    Heated bed
    Hi Hoss,
    I noticed in one of your pics that you now have a new surface on top of your heated bed. Is that glass, acrylic or? do you run a thermistor on the heated bed or just put 12 v to it?
    Sean
  17. #257
    It's a pretty common idea to use a piece of tempered glass on top held with paper clips at the edges.
    That heated bed warps pretty good at temp but the glass stays nice and flat and a flat surface
    to print on is paramount especially when putting down the first layer.
    My glass is about 4mm thick, salvaged from an old end table.
    The blue painters tape helps the plastic stick and is cheaper than kapton tape.
    Hoss
  18. #258
    Apr 2004
    128
    Thermistor
    Hi Hoss ,
    do you have a part number for the 100k thermistors? And the tape that is used on the hot end.
    Sean
  19. #259
    I used some 1/4" kapton tape to hold the thermistor and resistor to the hotend.
    Mcmaster #7648A711
    and some 1/2" fiberglass with PTFE tape to put several wraps around it to keep the heat in, really made a big difference.
    Mcmaster #76495A52
    You can get a 100k thermistor from MakerFarm.
    100k Thermistor
    or at Mouser.com #871-B57540G104F I used one for the heated bed.
    Hoss
  20. #260
    A note on resistors for the hotends. They didn't have a 5W 5.6 ohm resistor for the J-head hotend I got at the time
    but a 3W 6.8 ohm is another commonly used size.
    I got one here along with my RAMPS kit.
    6.8 ohm 3W 5% Resistor | UltiMachine
    but they are a lot cheaper through Mouser or DigiKey. #W21-6R8JI
    The diameter is smaller though and although you can use a thermal paste, I made a few
    wraps of brass shim to go around the resister for a snug fit in the hole, transfers the heat very well.
    Hoss
  1. mhackney's 3D Printers
    By mhackney in forum 3D Printer / 3D Scanner Discussion
    Last Post: 04-04-2014, 09:17 AM
  2. ROBO 3D Printers
    By CNC_Kid in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-13-2014, 09:13 PM
  3. Why have 3D printers in the classroom?
    By cncadmin in forum 3D Printer / 3D Scanner Discussion
    Last Post: 10-23-2013, 04:10 AM
  4. 3D Printers why so quite on here?
    By xairflyer in forum 3D Printer / 3D Scanner Discussion
    Last Post: 07-17-2012, 04:55 AM
