587,405 active members*
3,120 visitors online*
Page 5 of 5 345
Results 81 to 87 of 87
  1. #81
    Hey am,
    I started working on bolting the ATC on the g0704 july of last year.
    Lost interest till Dec when I drew up some new toolracks that use the new TTS tools that slide in with grippers.
    Actually I side tracked and made the ATC 4 which uses the same type slide in rack with grippers last fall.
    http://www.youtube.com/user/hossmach...os?query=atc+4
    Haven't been back to it since but it would work with the new racks (12 or 16 tools) and a modded macro.
    I want to use something different for a change to swing the arm though likely would just go with an air cylinder but there are lots of choices.
    It's a stout and reliable ATC with tons of tool changes under it's belt already from it's days on the X2.
    Doesn't interest me enough right now to finish because I'm having too much fun with other projects.
    http://www.cnczone.com/forums/3d_pri..._printers.html
    Hoss
    Attached Thumbnails Attached Thumbnails 070411 033_1000x750_cropped.jpg   atc 5 12inch 12 tools slide in rack wedge layout with gripper.jpg   atc 5 15 5 inch 16 tools slide in wedge layout.jpg
  2. #82
    Jun 2014
    2
    Re: Hoss ATC Number 3
    I am new on CNC Zone
    I like your ideas about X2.
    Actually I am converting also a X2 to CNC,
    so your ideas are more than welcome.
    Today, I have tried to make a power draw bar
    like yours, but it fastens not a lot. It works, but
    I can turn the tool with my hand.
    And to release it, it needs a lot of force.
    I use 6 springwashers and a 18 mm direct collet M12
    Do you use special or modified collet ?
    Best Regards from Austria
    Gerhard
  3. #83
    Quote Originally Posted by gerhard_ne View Post
    Gerhard
    Are you using TTS tooling with the 3/4 shanks or did you make your own.
    TTS tools will need a 3/4 collet that has the face ground down for clearance.
    32086 - TTS-R8 adaptor collet
    They have a 3/4 collet for MT3 spindles though you'll need a 3/8-16 drawbar for it.
    30251 - TTS-MT3 adaptor collet
    Hoss
  4. #84
    Jun 2014
    2
    Hi Hoss
    I have made my own tool holder.
    I will make an ATC so I have made it so
    that it falls out himself when collet open.
    But Problem is solved allready, I use another 18mm collet
    and this collet works perfect, think Chinese Quality issue :-)
    But another problem comes up. With my originale spindle,
    the end of the collet looks out only round about 10 mm
    out of the gearbox.
    To work with a fix toolrack, I think more than 30 mm are needed?
    Which modification are to do with the spindle?
    BR
    Gerhard
  5. #85
    Can you share some pics of what you are talking about, I'm not quite understanding what you're saying.
    Hoss
  6. #86
    Jan 2006
    1
    HI Don
    love your website was wondering if you have plans for the 16 tool ATC changer carousel if so how can I find the link
  7. #87
    Quote Originally Posted by ronald305 View Post
    HI Don
    Sure thing.
    Hossmachine Store
    Hoss
Page 5 of 5 345
  1. Hoss ATC Project
    By hoss2006 in forum Benchtop Machines
    Last Post: 04-06-2018, 07:56 AM
  2. Hoss's 3D Printers
    By hoss2006 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 01-27-2015, 04:05 PM
  3. Hoss's ZX45
    Last Post: 09-06-2012, 03:23 PM
  4. Original Hoss X2
    By baithog in forum Benchtop Machines
    Last Post: 11-21-2011, 02:17 AM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
