587,756 active members*
3,262 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > horizon (vision) engraver
Results 1 to 6 of 6
    Oct 2003
    7
    First time here. just picked up a 24x48 horizon engraver made by Vision engravers about 1995. There is a computer & controller with the machine. Coming off the engaving table is a 4 prong plug with 3 pin, I believe this is power to the spindle motor but cant find a power supply to hook it up to? Anyone using a Horizon or older Vision engraver? Looking for any info on table and controller(soft ware that was used with controller?)?
    Vision engraving has little info, they will sell new controller for 5895.00. If I cant revive the old I will have to look for used or make my own. Looked at ghina controllers but dont now?
    thanks dennis
    Nov 2008
    5
    You are correct, that is the plug for the spindle motor. It required 0-90 volts DC power. Vision can sell you just the 90 volt speed control board for $179. The part number is 503500-00.
    Jan 2009
    237
    A Variac, Bridge rectifier and perhaps a capacitor will provide 0-90V if you want to "home brew" ;-)
    The Baldor DC motor drive units show up on the used market as well.
    The Vision Engravers are great units, and having the motor supply integrated is a nice feature!
    Oct 2003
    7
    Thanks for the info on the Vision engraver. There is also a Horizon Controller with the table.
    Can anyone tell me anthing about a Horizon controller made mid 90's. It powers on but that all I can test right now?
    Thanks Dennis
    Nov 2008
    5
    That controller was made by Engraving Systems Support in Dade City Florida. Their website is http://www.engravingsys.com/ and they should be able to help you with the Horizon controller.
    Oct 2003
    7
    Thanks, got intouch with engraving systems, they have a power supply for the spindle motor(260.00). Also said they could help with the controller. Will let you now how it turns out after parts get here.
    thanks dennis
    any idea what type of software runs on a Horizon engraving system. The new systems run Vision, but the older machines?
  1. EZ Vision
    By TravisW in forum Bridgeport / Hardinge Mills
    Last Post: 03-04-2011, 03:33 PM
  2. EZ Vision back-up?
    Last Post: 11-09-2009, 10:03 PM
  3. argh! money and time spent, but no machine on the horizon.
    By posix in forum DIY CNC Router Table Machines
    Last Post: 03-29-2006, 03:04 AM
  4. Help, Anyone heard of a AEW Horizon Mill?
    By crazyman in forum Knee Vertical Mills
    Last Post: 04-06-2004, 04:07 PM
