Good evening all.
Working my way through a spindle bearing replacement on my Hiteco QD-1F and ran into a bit of a snag. I was not able to find a guide (or even pictures) of how the main shaft comes apart. I need to remove the top two bearings and replace them (see pictures), I've gotten down to the end and I can't figure out how to get at them. Rather I don't want to break something by pounding on it the wrong way. Is anyone aware if you can remove the top ring capturing them or do you have to remove all the bearings on the nose end by dismantling the entire shaft?
thanks,
