587,657 active members*
6,639 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > HITEC TURN 25G won't start up and showing "NC UNREADY"
Results 1 to 4 of 4
    Dear All,
    Hitec turn 25 G won't start up , after system RAM , window RAM, system ROM check, it will do the check for NC status check and then not start and showing only NC UNREADY on the screen
    can anyone help
    sting
    Aug 2009
    1573
    Re: HITEC TURN 25G won't start up and showing "NC UNREADY"
    Check Limit switches all Axis, possible Shear plate broken..if yours has them..
    What happen when machine starting having problems?
    Quote Originally Posted by machinehop5 View Post
    it does not start
    Oil in the oil reservoir?
    Sent from my SM-G950U using Tapatalk
  1. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  2. Please help.... "%" sign keeps showing up in code
    By 7379df in forum Uncategorised CAM Discussion
    Last Post: 10-31-2017, 03:59 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
