587,203 active members*
3,359 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Hitachi WJ200 Homing function
Results 1 to 2 of 2
    Aug 2006
    143
    Hi
    I'm trying to get the homing function working on my WJ200. Here are my settings:
    P068 = (00) low speed
    P069 = (00)* Forward direction
    P070 = ( .2 ) HZ*LS frequency
    C6 input (*69*)*ORL** Index Signal
    C5 input ( 70*) ORC* Start homing trigger
    C021 output 11 *(23) POK* positoning complete
    When I activate pin 5 it is my assumption the spindle should turn clockwise at .2 HZ until it sees a signal on C6.
    When I activate pin 5 nothing happens.
    Has anyone ever managed to get homing working?
    Derek
    Aug 2006
    143
    Re: Hitachi WJ200 Homing function
    Fixed it. It needs to have an encoder wired up to do any positioning including homing.
    You also need to make sure your logic is wired for source and not sink.
  1. Hitachi WJ200 1,5kw
    By MBViklund in forum Novakon
    Last Post: 09-14-2016, 11:04 PM
  2. Hitachi WJ200 2.2kW Output Relay?
    By shaddr3 in forum Spindles / VFD
    Last Post: 11-17-2015, 05:07 AM
  3. Hitachi WJ200 Help
    By szavoda in forum Spindles / VFD
    Last Post: 10-03-2015, 12:05 PM
  4. WTB: VFD HITACHI WJ200-022SF New/Used
    By Contract_Pilot in forum Want To Buy...Need help!
    Last Post: 08-28-2015, 09:48 PM
  5. Hitachi WJ200 Settings Help
    By BanduraMaker in forum Spindles / VFD
    Last Post: 10-09-2014, 05:25 PM
