587,518 active members*
3,463 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > High intensity lights...bypassing door switches?
Results 1 to 19 of 19
    Jan 2011
    51
    Is there a software way to do this? Or hardware? I just want to be able to turn them off and on as I please, as any good control freak would!
    Apr 2005
    713
    Close the door 1/2" from fully open to turn off.
    Jan 2011
    51
    Software or hardware, meaning in the controller. Anyone?
    Quote Originally Posted by Matt@RFR View Post
    Apr 2005
    713
    I know what you were asking, but there is no way to do it unless you want to hook the lights up to an M code if you have spares. Seems like a lot of work when just moving the door a tiny bit does the same thing.
    Jan 2011
    51
    Let's just say, purely for the sake of argument of course, that there is no way that the controller knows the state of the doors. In this extremely unlikely scernario, I'd like to be able to turn those lights on and off with a push button. Ultimately I'd like to replace those halogen lights with LED lights anyway, and in that case I won't have to worry about cooking the paint on the top of the doors. So no need for auto shutoff.
    Jan 2007
    1389
    Mark,
    just wire in a on off switch into there.
    kinda like the inside lights that have the on off switch on the right side of the panel. below the usb port. I have one on mine for the inside lights.
    matter of fact you may be able to use that switch. just be sure to check voltage.
    no m codes needed.
    Delw
    Apr 2005
    713
    Is there not a roller switch on top of the right hand door? My '07 VF-2ss is done that way, and if I wanted, I could simply extend the wiring for that switch and move it elsewhere and use a toggle switch.
    Jan 2004
    539
    Quote Originally Posted by MarkSerbu View Post
    Let's just say, purely for the sake of argument of course, that there is no way that the controller knows the state of the doors. In this extremely unlikely scenario, I'd like to be able to turn those lights on and off with a push button. Ultimately I'd like to replace those halogen lights with LED lights anyway, and in that case I won't have to worry about cooking the paint on the top of the doors. So no need for auto shutoff.
    Yes in that unlikely scenario..wink wink I have that same scenario.
    I never installed my High intensity lights for just that reason..still sitting in the box. Should sell that by the way..:idea:
    I was at SEMA this year and one of the main things I was looking at was LED's. Sooo many choices but the great way to go. Just need a little time
    Gary
    Jan 2011
    51
    Thanks, Del, but I'm pretty sure these are low voltage switches which just give a digital input to the controller. Routing 110VAC through high watt halogen lights would probably fry them in short order!
    Quote Originally Posted by Delw View Post
    Mark,
    no m codes needed.
    Delw
    Jan 2011
    51
    Finally, someone reads between the lines!!
    Yeah, I was just hoping there'd be a clean way to do this but apparently not. No big deal. Yes, LEDs are very cool! Even have them as headlights on one of my motorcycles.
    Quote Originally Posted by Kool Parts View Post
    Gary
    Nov 2007
    1702
    Just turn them on and off using the switch on the lights. Or don't they come with that switch anymore? Or did all of you forget that they have a rocker switch on the side of one of the housings?
    Greg
    Feb 2010
    1184
    Quote Originally Posted by Donkey Hotey View Post
    The only switch for the lights on a newer machine is located at the side of the pendant which controls both the interior and the HIL.
    That said, I don't think that controlling the lights is the real issue here.
    Apr 2005
    713
    Why would you make people read between the lines? There are a bunch of threads already devoted to bypassing the door interlocks, all in plain english about exactly what they want to do, and no arrests to date that I'm aware of.
    Most people here are kind enough to take time from their probably busy day to help people with issues they are having. You are just waisting their time by beating around the bush.
    Jan 2011
    51
    I'll make a deal with you: I won't gripe at you for wasting my time by your being obtuse, and you don't gripe at me for requiring people to read between the lines. :violin:
    Jan 2004
    539
    No reading between the lines, just common sense. And there are very good reasons for it.
    Back to the issue..what would be great is a replacement bulb for those lights. Some company will do it and sell a bunch in the process.
    I was just in a commercial electrical supply the other day buying some SO cord for the new machine. In the showroom they had a 4ft florescent bulb that was made up of dozens of led bulbs. Very cool.
    Gary
    Apr 2005
    713
    You would have gotten a lot better help if you just said what you meant. No skin off my back.
    Jan 2004
    539
    Well I did a bit of searching and it looks like someone is already doing replacement bulb. These might just be the ticket.
    R7S, LED Light Bulbs, Search LightInTheBox
    8W R7S LED Floodlight Replacement Lamp | Portable Work Lights and Bulbs | Work & Off-Road Lights | Super Bright LEDs
    Gary
    Jan 2011
    51
    Wow...this LED stuff is exciting...more and more stuff coming out every day! I was hoping that there was just some way internal to the controller that we could bypass the current logic. Is the "ladder" accessible in the Haas controller? Barring that, we may all just have to go to some sort of external power and switches for add-on lighting. Oh, well. I've wasted worse money than what the high intensity lighting costs.
    Gary
    Nov 2007
    1702
    I'm still lost. You bypassed your door switches so the control always thinks they're closed? And this messes up the operation of your HIL?
    I assume we're talking about a post 2010 machine then because both of our late 2009s with HIL are controlled by the old roller switch.
    If that's the case, find where the wiring terminates on the I/O board and disconnect it. Wire it to the screw terminals on the GFCI outlet on the side of the cabinet (same as how the HIL was installed in years past). Add a switch wherever you want. You may have an extra knockout or two in the side of the pendant. Add it there.
    I finally added a 4 foot fluorescent to the bridge on our GR-712 using that method: a 125v rocker switch, in the factory knockout. Ran a loop out to the pendant and back for that switch. Ran insulated 12/3 wire through the factory wiring tracks and installed the fixture. Connected everything next to the GFCI.
    Looks factory and works like factory. Should have been an option (even used the factory shipping bracket holes to mount it).
    Greg
  1. Installing high intensity lights...J4 or J8?
    By MarkSerbu in forum Haas Mills
    Last Post: 11-15-2012, 06:05 PM
  2. E-Stop,Limit Switches - Car door open switches ?
    By TrickyCNC in forum DIY CNC Router Table Machines
    Last Post: 04-19-2012, 09:55 PM
  3. Bypassing door hold and door locks on 2011 VF?
    By locash in forum Haas Mills
    Last Post: 04-05-2012, 04:31 PM
  4. No door saftey switches with 2 N.O.s?
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-20-2011, 04:41 PM
  5. 8' high mill through a 7' high door?
    By iandm in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2006, 03:12 AM
