Re: Help with KFLOP servo wiring and set up
There is roughly two ways out there to wire the E-stop circuit, use all the individual recommendations from each supplier of the component parts and then there's the common practice used by the industry for some considerable time and the NEC code and NFPA79, this entails including a hardwired method that includes any O.T. limits Watchdog timer/Charge pump etc.
Which ultimately removes power from motorized devices and usually all output devices, inputs and the controller itself can remain powered.
The controller is also advised of an e-stop via an input.
Al.
Albert E.
