586,061 active members*
4,702 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Help with Cutter Compensation.
Results 1 to 13 of 13
    Mar 2015
    4
    Hello, I am using a Haas VF-1. Cutter compensation seems to be working partially as the tool is off to the left side of my path using G41. However when I changed the diameter of the tool in the tool offsets page it doesnt seem to change the offset of the tool.
    Help please! I spent 3 hours pulling my hair out trying to solve this today.
    Nov 2005
    28
    Re: Help with Cutter Compensation.
    Care to post some g-code?
    Mar 2015
    4
    O51500;
    N1 T01 M06 (.500 DIA ENDMILL);
    N2 90 G54;
    N3 G00 X-.75 Y1.425 M03 S5000 (MILL FACE);
    N4 G43 H01 Z-.015;
    N5 G01 X4.0 F40.0;
    N6 G00 Y.950;
    N7 G01 X-.75 F40.0;
    N8 G00 Y.475;
    N9 G01 X4.0 F40.0;
    N10 G00 Y0;
    N11 G01 X-.75 F40.0;
    N12 G00 Y-.475;
    N13 G01 X4.0 F40.0;
    N14 G00 Y-.950;
    N15 G01 X-.75 F40.0;
    N16 G00 Y-.1.425;
    N17 G01 X4.0 F40.0;
    N18 G00 Z1.0;
    N19;
    N20 (MILL HOLE);
    N21 G00 X1.250 Y0.0);
    N22 Z.01;
    N23 G150 P51502 X2.125 Y0.0 Z-1.080 G42 J.125 K.02 Q.1 R.1 D01 F15.0;
    N24 G40 X1.250 Y0.0;
    N25 G00 Z1.0;
    N26 G28;
    N27;
    N28 (OUTSIDE PROFILE);
    N29 T02 M06 (.375 DIA ENDMILL);
    N30 G00 X-.500 Y.531 M03 S6000;
    N31 G43 H02 Z-0.0;
    N32 M97 P85 L22;
    N33 G40 G00 Z1.0;
    N34 G04 P30.0
    N35;
    N36 (FINISH OUTSIDE)(CHANGE DIA T02);
    N37 G00 X-.500 Y.531 M03 S6000;
    N38 G43 H02 Z-.550;
    N39 G41 G01 X-.250 Y.531 F30.0;
    N40 X.0;
    N41 X.875 Y1.076;
    N42 X1.6875;
    N43 G02 X1.875 Y.8885 R.1875;
    N44 G01 Y.576;
    N45 G02 X1.875 Y-.576 R.688;
    N46 G01 Y-.8885;
    N47 G02 X1.6875 Y-1.076 R.1875;
    N48 G01 X.875;
    N49 X0.0 Y-.531
    N50 G01 X-.500;
    N51 G00 Y.531 (RAPID TO BEGINNING);
    N52 Z-1.080 (SECOND PASS);
    N53 X.0;
    N54 X.875 Y1.076;
    N55 X1.6875;
    N56 G02 X1.875 Y.8885 R.1875;
    N57 G01 Y.576;
    N58 G02 X1.875 Y-.576 R.688;
    N59 G01 Y-.8885;
    N60 G02 X1.6875 Y-1.076 R.1875;
    N61 G01 X.875;
    N62 X0.0 Y-.531
    N63 G01 X-.500;
    N64 G00 Z1.0
    N65 ;
    N66 (RADIUS EDGE);
    N67 T03 M06 (.125 RADIUS END MILL);
    N68 G00 X-.500 Y.531 M03 S5000;
    N69 G43 H03 Z-.120;
    N70 G01 X0.0 F25.0;
    N71 X.875 Y1.076;
    N72 X1.6875;
    N73 G02 X1.875 Y.8885 R.1875;
    N74 G01 Y.576;
    N75 G02 X1.875 Y-.576 R.688;
    N76 G01 Y-.8885;
    N77 G02 X1.6875 Y-1.076 R.1875;
    N78 G01 X.875;
    N79 X0.0 Y-.531
    N80 G01 X-.500;
    N81 G00 Z1.0;
    N82 G28;
    N83 M30;
    N84 ;
    N85 (OUTSIDE SUBPROGRAM);
    N86 G91 Z-.050
    N87 G90 G41 G01 X-.250 Y.531 F30.0;
    N88 X.0;
    N89 X.875 Y1.076;
    N90 X1.6875;
    N91 G02 X1.875 Y.8885 R.1875;
    N92 G01 Y.576;
    N93 G02 X1.875 Y-.576 R.688;
    N94 G01 Y-.8885;
    N95 G02 X1.6875 Y-1.076 R.1875;
    N96 G01 X.875;
    N97 X0.0 Y-.531
    N98 G01 X-.500;
    N99 G00 Y.531 (RAPID TO BEGINNING);
    N100 M99;
    O51502;
    N1 X1.25 Y.4375;
    N2 X1.5;
    N3 G02 X1.5 Y-.4375 R.4375;
    N4 G01 X1.25;
    N5 G02 X1.25 Y.4375 R.4375;
    N6 M99
    Nov 2005
    28
    And just where are you having trouble? N37? I don't see any G40 being used either.
    Mar 2015
    4
    N66 is where im having the most trouble. I cant get my radius cutting end mill to radius the profile. It goes right beside the edge of the stock and no matter what value i place for the tool in the tooling offset page it keeps cutting about the same distance away.
    What do you mean no G40? Forgive me im not a regualar CNC programmer.
    Feb 2011
    353
    try putting a d2 on line 87 of the program to get the tool offset for tool 2
    rcs60
    Jul 2004
    100
    Yeah, I see that D02 is missing. I often lose a part because I forget the "D."
    I am now in the habit of putting the D in right when I call the tool;
    T3 D3 M6
    I have been meaning to edit the quick code to add the D to the tool change as well.
    ​"There is no such thing as a gun free zone."
    Ray Brandes, Ray-Vin.Com, PCB, FL 32408 USA
    Nov 2007
    479
    I always put "D" in my G41/G42 lines.
    Jul 2004
    100
    Quote Originally Posted by djr76 View Post
    I try to, but I forget. G13 usually suffers too.
    Mar 2010
    1852
    This is the proper way to do it. After all, you may call a G41 or G42 with a D or tool # that is not the tool you are using.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Jul 2005
    12177
    Alternatively you may want to use two different Ds for the same tool.
    Mar 2010
    1852
    Quote Originally Posted by Geof View Post
    Not alternatively, that is exactly what I mean. I do use two different offsets for the same tool once in a while within the same tool run.
    Mike
    Nov 2007
    479
    I do the same thing regularily, rough n finish pass, maybe incorporate a subroutine profile instead of copy n paste.
  1. Inte200 MK4 Matrix control - Milling cutter EIA cutter radiusr compensation G41
    By Stavros Flatly in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2013, 02:48 AM
  2. Cutter Compensation D ?
    By Chappyd in forum G-Code Programing
    Last Post: 12-16-2012, 12:32 PM
  3. Cutter Compensation
    By TravisR100 in forum NCPlot G-Code editor / backplotter
    Last Post: 10-31-2010, 08:09 PM
  4. Cutter Compensation?
    By Joe Petro in forum Autodesk
    Last Post: 03-08-2006, 07:04 AM
  5. Cutter compensation?
    By Tonenc in forum G-Code Programing
    Last Post: 11-03-2005, 06:53 AM
