Thankyou cadcam
And thank billystein and Streve Arteman for their input to my learning curve.
The empty MC9 file reason was detailed in my original post. You had enough to set the ball (nose cutter) rolling.
I always try to make perfect models.
Somebody else made this one. I split it through center with ACAD and it didn't crash ACAD so can't be too far out.
I will see if I can get SWorks to repair it.
Thank you for setting me on the right track. I thought pockets were hollow, but I see your approach. Hope I can speed up the ridiculous process time.
There are so many different approaches, with so many possibilities to try, and it takes a long time to test each one. Again thank you.
I am coming to grips with making compensation work, let alone the rest of the CNC. I have been hand carving code for too many years.
Once I repair the model to get rid of the non-coincident lump I will cut one.
The only way I could split it in ACAD was to slice in YZ plane before slicing in XY plane. I new the model was a bit corrupt, but I've sure learnt a lot.
Cheers.
Neil.
