587,719 active members*
3,494 visitors online*
Results 1 to 12 of 12
    Feb 2012
    87
    Help SolidCAM and rpm
    Hello everyone, I'm new in SolidCAM and have a question and safe for you is easy, I want to use an engraving tool 0.1mm and selecting a speed of 20000rpm I get this error, as I can fix this?
    please see the attached image.
    Luis
    Oct 2013
    64
    Re: Help SolidCAM and rpm
    You'r machine can rotate that much?
    Feb 2012
    87
    Arikaa, I mean speed of the spindle is 2.2kw to 24000rpm , I have to mention that I am a novice in SolidCAM, so I need help
    Oct 2013
    153
    Open the machineID file and change the RPM to 24000
    Feb 2012
    87
    thanks you, I've got a video on your feedback https://www.youtube.com/watch?v=g0Rt-072Hr0
    Now I have to find that post processor is compatible with my Chinese machine:drowning:
    Feb 2012
    87
    Hello everyone, I have a new problem emerged, I tried to make the paths by selecting the generic post processor fanuc.
    I have an error this file is missing gMill_Generic_Fanuc_X_4x_Eval.GPP(check the image), please kindly someone can send me ?, thank you very much.
    Oct 2013
    153
    By default the gpp file is located in C:\users\public\public documents \solidcam\solidcam2015\gpptool . Check whether the file is there or not ! If the file is missing then just reinstall the post processors
    Feb 2012
    87
    I've looked but not found in the picture looks, my version is 2014, please can you share
    Hey,
    you have to put postprocesors to that location
    C:\Users\Public\Documents\SolidCAM\SolidCAM2015\Gp ptool
    and then set in solidcam settings -> Default CNC-Controler , then in first row you find that location and confirm it.
    You have to have 3 files for one machine with next extentions ( .GPP .PRP .vmid )
    Oct 2013
    153
    hi here is the files good luck!
    Feb 2012
    87
    Thank you very much for sharing this file :cheers:
    hey bro i need those 3 files
    .gpp .prp .vmid for my siemens 828d controll for solidcam
    plz help
    if u can send me the post processor file i shall be thankful for that
    my email is [email protected]
  1. SolidCAM g76 to G33/G92
    By vdKroon in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-14-2013, 03:30 PM
  2. Considering SolidCAM
    By martin_05 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-05-2009, 09:53 AM
  3. Who's using solidcam?
    By jmcglynn in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-13-2009, 04:03 PM
  4. SolidCAM and 64 bit
    By Adam Hubert in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-27-2008, 06:52 PM
