587,210 active members*
3,029 visitors online*
Results 1 to 6 of 6
    May 2013
    0
    Help Selecting Turning Lathe
    Hi All,
    I am revamping machie shop, replacing the traditional manual lathes with CNC Lathes. My requirement is to install 24 lathes in next 12-18 months timeframe.
    The CNC Lathe operations would be turning and facing - its a cylindrical job with height of max 75 MM and max OD of 460 MM
    The machines short listed are:
    HAAS: ST-40
    DOOSAN: V 400
    HYUNDAI: LV 500
    MORI SEIKI: CTX 510
    OKUMA: SP-V60R
    MAZAK: QSM 350
    Since this is quite a huge investment, I wanted expert opinion / experiences on the same.
    -THANKS
    May 2013
    11
    I've ran mori seikis quite a bit. super dependable and extremely rigid. Combined with a automatic steady rest, it works perfect to face, center and turn all with one set up.
    Nov 2012
    70
    If this is the only work you will do, I would definitely recommend one of the vertical lathes. Much higher rigidity provide better possibilities for effective turning. Also much more ergonomic loading/unloading. If you want real production there are vertical lathes with hanging spindle (free chip fall) and where you load the parts outside machine on conveyors and the the spindle itself pick up / leave the part on the conveyor belt
    Regarding the Mori Seiki CTX510 I don´t think this is an original Mori Seiki. As far as I know it´s a DMG lathe (originating from the Gildemeister line)
    May 2013
    0
    Thanks Swede!
    Can you recommend lathes that have hanging spindle that allow part load/unload outside - it will definitely boost production levels.
    Any specific recommendation on the Vertical Lathes?
    Thanks,
    Jigar
    Nov 2012
    70
    Hi Jigark,
    The absolutely most sold machine of this type in Sweden is Emag made in Germany EMAG machine tools ? turning machines, grinding machines
    There are also two other German made machines that are rather common in Sweden
    Hessapp range DVH and DVT. Hessapp is nowadays a part of the MAG-IAS Group MAG - The Global Machine Tool Manufacturer: MAG
    DMG with their CTV-range is also an alternative, but I think Emag and Hessapp are sturdier machines
    The only Jap I know have made this type of machine is Hitachi Seiki with their CS-range. As you probably know Hitachi Seiki went bankrupt 10-12 years ago. Mori Seiki bought the remains, but I don´t think they continued manufacture this range very long. These machines can be bought secondhand at low prices here in Europe because of Mori Seikis very poor support for these machines. Don´t know about the support in US
    For your Steady Rest requirement you can consider going for Steady Rest manufactures in India. They offer same quality at nearly half the price of US & German manufactures.
    ARMS Steady Rest is a leading Steady Rest Manufacture & exporter from India and have their client base in India, US & Finland.
    ARMS Steady Rests are at par with international standards and very competitive in price. They can be used as replacement to any other make due to its unique design which enables interchangeability in mounting dimension. They can be used on any CNC make.
    To see our catalog, please visit this link ARMS AUTOMATION : Hydraulic Steady Rest
    To see the images of our Steady Rest manufactured by us please visit this link ARMS Hydraulic Steady Rests
    K Stephen Daniel
    [email protected]
  1. Help selecting machine - VMC vs. Lathe
    By rcsimpson in forum Uncategorised MetalWorking Machines
    Last Post: 02-28-2013, 05:20 PM
  2. Selecting good lathe inserts
    By mikewohlford in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-18-2011, 01:58 AM
  3. need help in selecting ballscrews and etc for 10 24 lathe project
    By Hiredgun in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2011, 01:31 AM
  4. doing 10-24 cnc lathe project help with selecting parts
    Last Post: 01-16-2010, 04:11 AM
  5. need help in selecting ballscrews and etc for 10 24 lathe project
    By Hiredgun in forum FAQ of DIY CNC Machine Building
    Last Post: 01-13-2010, 06:13 AM
