587,486 active members*
3,919 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help! Rotary axis feedrate
Results 1 to 4 of 4
    Apr 2005
    713
    I'm using a friend's seat of MCX while he's out of town trying to get a christmas present made for my wife. I've got everything programmed, but when I post the code, the feedrates are almost all over the max feedrate of my 4th axis. Machine is a '07 Haas VF-2ss with an '07 HRT160 4th if that matters. Max feedrates for the machine AND 4th is 833ipm, but the posted feedrates are anywhere from 148 to 2000.
    I've been in the Machine Definition Manager, and the max feedrates there are 833, which is what I need, but not what it's posting out.
    What gives? What am I doing wrong? Any help would be greatly appreciated! I've only another day to get this made, or I'm in big trouble.
    Edit: I meant to mention that this part is looking like it'll have right around 700,000 lines of code, which is why I'd really like to fix the post and not hand modify the code a few thousand times.
    Sep 2007
    217
    Need to see on the feed settings is at unit/min and not inverse time in the control definition.
    Apr 2005
    713
    Thanks for the reply. Yes, everything in the control and the machine definition managers is set to unit/min.
    Apr 2003
    3578
    Do you see a G93 that is inverse active callout?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-12-2013, 09:32 AM
  2. 4 Axis Feedrate Calculation
    By cbr120 in forum MetalWork Discussion
    Last Post: 12-12-2007, 06:20 PM
  3. 4 axis rotary simulation
    By alexandrufelipe in forum EdgeCam
    Last Post: 06-22-2007, 11:35 AM
  4. Dro on a rotary axis.
    By Smackre in forum DIY CNC Router Table Machines
    Last Post: 01-16-2007, 02:45 PM
  5. 4 Axis Rotary
    By Smackre in forum Mastercam
    Last Post: 08-09-2006, 05:28 PM
