587,477 active members*
3,572 visitors online*
Hybrid View
    May 2003
    3
    Help with post change
    How can I change my post processor to change my program in the following way?
    Processor is for a Cincinatti Talon lathe (modified 850 sx post processor)
    I need to change where the tool comment is, and add the G95 and Feedrate into the same
    line as the G96 line.
    Included is a simple program, written as it is coming from the post processor, and written as
    how I would like it:
    1st one is what the post processor is writing
    2nd one is the changes I want to make
    (MSG, TOOL - 1 OFFSET - 1 )
    (MSG, LROUGH OD ROUGH RIGHT - 80 DEG. INSERT - CNMG-432 )
    :1G0G62G70G97S191M4T1M6X4.Z6.
    N1G92S3000
    N2G0X1.3527Z.11M8
    N3G96R1.3527S200
    N4G95G1Z-.99F.01
    N5X1.5F.01
    N6X1.6414Z-.9193F.01
    N7G0Z.11
    N8X1.2054
    N9G1Z-.99F.01
    N10X1.3727F.01
    N11X1.5141Z-.9193F.01
    N12G0Z.11
    N13X1.058
    N14G1Z-.99F.01
    N15X1.2254F.01
    N16X1.3668Z-.9193F.01
    N17M9
    N18G0X4.Z6.
    (MSG, TOOL - 2 OFFSET - 2 )
    (MSG, LFINISH OD FINISH RIGHT - 35 DEG. INSERT - VNMG-431 )
    :2G0G62G70G97S286M4T2M6X4.Z6.
    N19G92S3000
    N20G0X.5Z.1M8
    N21G96R.5S300
    N22G95G1Z0.F.005
    N23X.9587F.005
    N24G3X1.Z-.0206I.9587K-.0206F.005
    N25G1Z-1.F.005
    N26X1.5F.005
    N27X1.6414Z-.9293F.005
    N28M9
    N29G0X4.Z6.
    N30M05
    N31M02
    I would like to change the comment line to go after the tool call line.
    Also get the G95 and Feed Rate in the line with the G96 callout.
    N1G92S3000
    N2G0X1.3527Z.11M8
    N3G96G95R1.3527S200F.01
    N4G1Z-.99F.01
    N5X1.5F.01
    N7G0Z.11
    N8X1.2054
    N9G1Z-.99F.01
    N10X1.3727F.01
    N12G0Z.11
    N13X1.058
    N14G1Z-.99F.01
    N15X1.2254F.01
    N17M9
    N18G0X4.Z6.
    N19G92S3000
    N20G0X.5Z.1M8
    N21G96G95R.5S300F.005
    N22G1Z0.F.005
    N23X.9587F.005
    N25G1Z-1.F.005
    N26X1.5F.005
    N28M9
    N29G0X4.Z6.
    N30M05
    N31M02
    May 2003
    3
    ttt
    Anyone????
    Aug 2006
    19
    is this a mastercam post?
    Can you give me the post file?
    Those changes sound easy and I think I could help you with it.
