Kitamura MC 1 ser.#02196
I have lost parameters on this machine and have researched how to put them back in but when I get to the point of actually installing them I have ran into a snag and need some guidance on how to do this,here is an example of what my problem is;
I have the parameters on paper hard copies
on one set of parameters it reads like this;
N0001 P 00010100
N0002 P 00000010
N0003 P 10100000
N0121 P 00000100
N0136 P 00000007
N0735 P-00242500
And the next set that has the serial # for the machine sent with it from the factory (I assume) looks like this;
N001 .....1..
N002 ......11
N003 1.1.....
N121 .....100
N136 .......7
N735 .-242500
N906 ..1.1...
There are a few that are a little different I plan to use the set thet came with the machine but do I enter a 0 for a . or how do I enter a . in the line ? My monitor had the periods in the line not 0's so there has to be some way to enter the period ?
And why would the par #2 be different ?
Will I have all the parameters I need or were some put in by Fanuc Tech. I have all the original paper work for the machine and it list options that came with it I do know it had a fourth installed but not sure if I have what I need to put that in.
