587,890 active members*
3,050 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Help Needed with cutting Letters
    Jan 2012
    0
    I have a old Pacer CNC machine with updated drivers and software. XMC-E
    I am trying to cut a sign in Large letters approx 150mm high in New Times Roman.
    I did the drawing in AutoCAD 2010 first then transfered it to the CNC software, when I cut the letters out the large curved letters such as "O" come out Faceted not curved Iset the machine to the highest curve setting. Any idea what I am doing wrong? Do I need a special font ?
    Sep 2008
    37
    Have you tried looking at your output settings?? this could be used to decrease the file sizes
    have you tried saving as a different file type to see if that helps?
    There is always another option.
    Jan 2008
    66
    We often trace over text with splines, lines and arcs. You could try that. However, it sound like you're pretty sure the problem is with your CAM or machine, rather than CAD. Is that correct?
  1. abs cutting help needed
    By loyedp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-04-2010, 08:11 PM
  2. Cutting letters with outlines
    By neonlady in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-21-2008, 05:48 AM
  3. Cutting 2" Foam letters
    By routski in forum Material Machining Solutions
    Last Post: 01-10-2008, 11:57 PM
