587,427 active members*
4,668 visitors online*
Results 1 to 6 of 6
    May 2008
    37
    Red face Help on my small list
    Hi sorry to start a thread like this
    I was just making sure that this will work before I order, as I allways have bad luck when buying things like this =
    This = HobbyCNC EZ Driver Board Kit
    http://www.hobbycnc.com/products/hob...ver-board-kit/
    with 3 x NEMA 23 1-Amp Unipolar Stepper Motor
    using the Daisy chaining computer PSU idea of 3 psu's
    http://www.cnczone.com/forums/showthread.php?t=17548
    The psu's I have allready as I have 100's of computer stuff, but might not use that idea yet I just thought I would ask aswell.
    This is for a router / engraver table I want to build its going to be no more than 12" x 12" for the table.
    any thoughts?
    as I am trying to keep cost low but have a nice machine.
    May 2008
    37
    also I forgot to ask, with the HobbyCNC EZ Driver Board Kit I will not need any other driver boards or anything like that will I?
    May 2008
    37
    Any one help on this?
    May 2008
    37
    I will just get them and find out
    Apr 2005
    403
    MadCad,
    Sounds like you have the plan down. The board has the breakout board function built in to it and you will only need to cable up the motors to it. I used one on a lathe that I converted a while back. Just take your time sodering the components and be careful to prevent solder bridges. Are you planning to use mach3?
    Ron
    May 2008
    37
    Hi thank you for your reply
    I am unsure what software to use yet, I want a software that is good, cheep and easy to understand I havent looked into them much yet, but I really want a software that I can just place pictures on and it do the coding from that :-S
  1. What's Next On Your Wish List?
    By widgitmaster in forum Polls
    Last Post: 08-28-2015, 10:08 AM
  2. Add another one to the list
    By jgro in forum CNC Wood Router Project Log
    Last Post: 05-13-2012, 07:03 AM
  3. I need a Shopping List
    By john_t_h in forum Syil Products
    Last Post: 02-25-2008, 08:26 AM
  4. Complaints or wish list
    By HAILINHAAS in forum Haas Mills
    Last Post: 10-29-2007, 11:28 PM
