I bought a used Minitech Mill2 and it did not come with much in the way of troubleshooting materials. I downloaded Mach 3 to control it. I have the parallel port hooked to my PC, the motor board hooked to the functioning power supply, and the control box plugged in. The spindle is plugged into the control box and runs, so power is making it there. The cooling fan turns on in the box when the power supply is turned on, so power is live there as well. After opening Mach and using the manual control screen (tab button) to test the movement, I'm left with nothing. No stepper motor movement, sound, nothing.
I am a total newb to this, so please help in laymen's terms. I don't know what to do to get this going!
