587,263 active members*
3,207 visitors online*
Results 1 to 18 of 18
    Sep 2006
    95
    HELP...interact 4 lost parameters
    I just bought a series 2 interact 4....got it home and powered it up and the screen is all in german and its asking for parameters before i can do anything else with it to see if everything works on the machine.
    I know some of you guys have them because i remember reading about someones interact 4 that needed them to all be reloaded. I replaced the 3 AA batteries in it already.
    Could one of you guys please help me out...I cant play with my new machine without the parameters loaded in.
    heres my email [email protected]
    May 2006
    10
    I had one of those once, with the same problem. Forget about the batteries and get a UPS from your local office suply computer shop and wire the controller to it. This is fairly easy and will give a more reliable memory backup. The manuals are available in PDF format from Heinenhein and should get you out of trouble.
    Jan 2005
    1121
    the batteries last about ten years, you do the math
    heidenhain can get you a generic parameter list, but I don't know how has the real list, I thought hardinge didn't support them
    Nov 2004
    3028
    I sent you a generic list. Did you not get it?
    George
    May 2006
    10
    Quote Originally Posted by gus View Post
    You must be as smart as you think you are. The batteries MIGHT last ten years if the switching circuit is ok on the CPU board. The UPS works either way and provides a well filter electrical power to keep your chips and such happy. The unit we had would last about twenty minutes on a new set of batteries. The UPS kept everything in for two years, maybe longer, we sold the machine, so I don't know how it's doing now. I have the technical manuals in electronic format and a list of parameters for our machine, if anyone needs them.
    Sep 2006
    95
    That you for the parameters that you emailed me. I typed them in the control and she powered up just fine. I just wanted to start the control up to see if everthing worked correctly before i do a retro. Im going to sell all the electronics off of it to one of the guys on this forum...
    Jan 2005
    1121
    re
    excellent, you oughta try running it as it is tho, if its at least a 151 it is a full 3 axis control and will run perty nice
    re: batteries, dontcha think ya oughta fix the problem rather than add complexity?
    I have 3 of the smaller heidenhain controls and they all get at least ten years
    Nov 2005
    15
    I recently replaced the handwheel on our series 2 interactII. During the process we lost the parameters but were able to reload a copy we had stored for such an occasion. However, not the controller only speaks in German. How do you get it to back to english? Is there a menu command or a machine parameter that needs to be reset?
    Ron
    Jan 2005
    1121
    re
    which control?
    151 is no 92, mine is 0, 3 might also make it english, but with a decimal point not comma, or something...
    Nov 2005
    15
    Sorry I didn't include the control. It's a 150.
    Changing para92 to 1 did change the comma to a point, but still German even after a reboot of the machine.
    I seem to remember a screen prompt that allowed the user to change languages... but I can't read the prompts anymore???
    Ron
    Nov 2004
    3028
    It is a parameter but I need my control book at the office to figure which parameter it is. By the way, using a decimal point instead of a comma creates its own issues. Some canned cycles do not work because they expect the commas.
    George
    Jan 2005
    1121
    re
    see, not 1, 0 or 3 or add 2 to err, something. the comma/decimal and language are handled by the same parameter,for some reason
    Nov 2005
    15
    A 2 did it. The book I have show that only 0 and 1 are valid inputs for parameter 92. But the control took the 2 and immeiately after hitting the DEL key everything returned to good ole english.
    Thanks for your help.
    Ron
    Sep 2006
    13
    I also have an Interact 412 with the 151 control, & I have alaso lost the parameters.
    I have all of the parameters in a .txt file.
    Dies anyone know if there is a way of simply downloading them into the machine? Rather than typing them all in?
    Jan 2005
    1121
    re
    when it turns on, it will be asking for parameters
    IIRC hit the ext key and you can download them via rs232
    connect the cable and fire up the computer software first
    Nov 2004
    3028
    You will need to go through the MOD key and set up baud rate and the fact that you will be using RS232.
    George
    Sep 2006
    13
    Thanks for the help, I wont have time to try for a couple of days. You may be hearing back from me by the end of the week
    Feb 2006
    60
    Quote Originally Posted by camarogod98 View Post
    What control is on it? I might just be interested in that... is it a 151???
  1. Bridgeport Interact 520/Heidenhain TNC 155 initial parameters
    By jeromir in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2018, 10:40 AM
  2. Bridgeport Interact 412/Heidenhain TNC 250 initial parameters
    By pedrow in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2014, 08:11 AM
  3. Lost fanuc 3T parameters
    By erikturn in forum Fanuc
    Last Post: 09-24-2014, 09:00 AM
  4. Lost parameters
    By darrylh in forum Fanuc
    Last Post: 06-09-2010, 08:02 PM
  5. Interact 412
    By code in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2008, 03:36 AM
