587,745 active members*
2,794 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Help identifying these collets
Results 1 to 5 of 5
    Mar 2004
    576
    I have a "Big" (brand) spindle speeder and it comes with some collets, but I need collets in other sizes. It has two different collet nuts for different-sized collets. The one on the left (B) looks like some "TG" collets I found at Maritool, but the sizes don't seem to match up. I also found other sizes of TG collets on the web, but can't find specs on them.
    What I need is a 1/4" collet. The top piece (C) is an adapter that converts 3/8" (of collet B) to 3/16". Perhaps someone makes a 3/8" to 1/4" adapter?
    Unfortunately, I forgot my sheet of paper with my measured dimensions at the shop, so I'll have to get those tomorrow. But IIRC, the opening ID of nut A is something like 0.55", and the opening ID of nut D is around 0.46". The hole in B fits a 3/8" endmill (or the adapter C). The hole in collet E fits a 1/8" endmill.
    Thanks,
    -Neil.
    Oct 2007
    97
    Those almost look like these (Link). But without measurements there is no way to know.
    John Torrez
    Think & Tinker / PreciseBits
    Mar 2004
    576
    I know, I screwed up by forgetting the dimensions, but here they are now...
    Nov 2008
    129
    Big Diashowa Tooling
    If the tooling you refer to is called BIG, I think you need Big Diashowa who are Japan No1 spindle tooling manufacturer, and they produce an 8 degree collet system like my old employer Nikken Kosakusho (but their collet will not interchange). You can try here for spares and ask for David James, or go to: http://www.big-daishowa.com/index.php NB. like every thing you get what you pay for, so make sure you are sitting down when you ask for them prices!
    regards
    Alan
    Mar 2004
    576
    Good leads, thanks! I also came up with a back-up plan to machine a 3/8" to 1/4" sleeve if it comes to that.
    Cheers,
    -Neil.
  1. Help Identifying This
    By WeaSiL in forum CNC Machine Related Electronics
    Last Post: 04-08-2009, 09:35 PM
  2. Need help identifying
    By pflynnjr in forum Stepper Motors / Drives
    Last Post: 04-18-2007, 05:58 PM
  3. Need Help Identifying a Bearing
    By lerman in forum Mechanical Calculations/Engineering Design
    Last Post: 10-08-2006, 03:38 PM
  4. Help needed identifying Tool holder and Collets
    By gtslabs in forum Uncategorised MetalWorking Machines
    Last Post: 03-20-2005, 08:25 PM
  5. Help identifying this please
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2004, 08:40 PM
