587,143 active members*
3,388 visitors online*
IndustryArena Forum > CAM Software > Mastercam > HELP ON FOURTH AXIS
    May 2009
    6
    Lightbulb HELP ON FOURTH AXIS
    Hello every body i have been programming with mcx for about two years but never had to program a fourth axis and my boss just bought one and i have to figure out howto program so we can machine three or four sides at a time can anyone please helpme to get started, any tips and advises are greatly appreciated, we are planning to build a tombstone so if you have any experience or you can send me to the right direction thank you all again.
    Dec 2008
    3122
    What machine do you have ? (make)
    Horiz. or Vert ?
    What axis is it around ? X or Y
    What version of Mastercam ?
    Post is modified from what generic post ?
    Normally:
    Vertical is around the X and the rotary axis is A
    Horizontal is around the Y and the rotary axis is B
    There are some exceptions
    Is it a positioning (indexing only, say 5° or 1° increment ) or full feed machining rotary ( 0.0001° increments )
    Your post must have this axis added into it, so you have functionality
    your reseller should be able to modify the post quickly enough for you
    As superman said you have to set up your Machine Definition with a 4th Axis and you have to have a post (.pst) that will handle it.
    If you are going to do Index programming, I would really recommend getting used to or using the WCS Manager. I use it everyday for our Horizontals.
    Mastercam's website has a little Tutorial about it. It is originally for V9, but works mostly the same for the X family.
    http://www.mastercam.com/Support/Documentation/Files/WCS-ViewMgrTutorial.zip
    Mike in MN
    http://www.cncbasics.com
    http://www.cncbasicsforum.com
    http://www.mastercamforum.com
    http://www.mastercamblog.com
    www.cncbasics.com
  1. Fanuc OM-C Fourth axis.
    By pauldkeeton in forum Fanuc
    Last Post: 10-31-2023, 08:50 AM
  2. R2E4 Fourth Axis?
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 11-14-2013, 03:42 PM
  3. Cutting an arc using a fourth axis
    By gplush in forum Haas Mills
    Last Post: 08-25-2009, 05:20 AM
  4. Anyone using a fourth axis???
    By Frogblender in forum Novakon
    Last Post: 07-29-2009, 12:47 AM
  5. fourth axis indexer
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 08-04-2004, 09:34 PM
