587,256 active members*
2,879 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > HELP: with Bosch 1617 wiring
Results 1 to 4 of 4
    Jun 2013
    3
    I recently rebuilt a used Bosch 1617 with new bearings and brushes while installing a SuperPID. I have everything back together, but when I wire it up and plug it in, the breaker trips. This is the Bosch model without the factory speed control, so aside from replacing the brushes, I haven't altered the wiring. I've tried every permutation without any luck and am really bewildered. I've tested the switch and power cord and both are fine.
    Here's a picture of what I remember to be the correct wiring arrangement : any help would be greatly appreciated.
    Mar 2013
    4
    Have u tried bypassing the switch? I will try to snap a photo of mine.
    Jun 2013
    3
    Thanks for the reply. Yes, I've tried bypassing the switch, but it doesn't make a difference. I'm pulling my hair out because this seems so simple, but here's a list of what I've checked:
    -Tried all wiring permutations
    -I've tested the mains: they're fine. And I've tested using other outlets: no difference.
    -I've inspected and cleaned the armature connection: they seem fine
    -Checked for any burnt coils: I don't see anything alarming
    -Brushes are brand new and have good contact
    -The switch has been tested and bypassed
    Mar 2013
    4
    Here is a coupling of photos and schematics. Maybe the stud terminals 22 are not connected correctly.Click image for larger version.
Name:	Bosch 1617.039 schematic[1].pdf
  1. Bosch EVS 1617 bearing failure
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 06-27-2012, 11:12 PM
  2. Bosch 1617 Feeds+Speeds table
    By Vestus in forum DIY CNC Router Table Machines
    Last Post: 06-18-2012, 07:50 PM
  3. Controlling Speed of Bosch 1617 via CNC
    By n1k86 in forum DIY CNC Router Table Machines
    Last Post: 07-15-2011, 11:02 PM
  4. Wiring a Bosch Colt to ground for homing.
    By barak1001 in forum Maintenance DIY Discussion
    Last Post: 02-02-2011, 09:32 AM
  5. Bosch 1617evs wiring under cap?
    By Dan Craig in forum DIY CNC Router Table Machines
    Last Post: 04-21-2009, 03:32 AM
