I am working with a TC4 with DX32 control, GibbsCam and a twisted postprocessor converted from imperial to metric.
Everything works perfectly but I have this annoying problem:
No matter what, the post is converting any circle in quads and while milling a small delay is made at every 90 deg. leaving a mark on the part.
As there is nothing inserted in the G Code (like dwell for example) I am wondering if there is anything to set on the controller to cancel this delay between arcs or something to be added to the code.
Any help will be highly appreciated.
