Hey CNC junkies,
Let me first start off by saying that there is no build that is impossible. That being said, I've heard a lot of people state that this build is impossible, but CAD models and FEA suggest that it may be feasible within our desired tolerances (+/- 0.003"). I plan on using this thread as a method of documenting the design for others to collaborate, and ask questions about the design as we run into problems.
Our shop is looking to design and fabricate a 4'x4'x30", 5-axis CNC router that will do 70% foam, wood, composite work and 30% light aluminum work. The proposed budget is currently at ~$10K-$15K. We are in the aerospace industry, so we work with aircraft tolerances, which means this machine has to be very rigid. We are using 4"x4"x0.25" ASTM A500 Grade B Steel for the frame, and 2"x2"x0.120" steel tubing for the structural members. The bed will be made out of a dense wood or composite material, and will include a lattice structure style torsion box. We will be implementing a dual-driven gantry, also made out of steel, and we plan on using rack and pinion drives (the kit from cncrouterparts.com) for the X, Y axes that drive the gantry and Z-axis assembly. The Z-axis itself will be driven using a 48" ballscrew. The gantry and X-axis will traverse along Hiwin Profile Rail guides, and the Z-axis will traverse along continuously supported shafting. The 4th and 5th axis capabilities will come from the Doughty Drive B/C rotary head. I am confident in our abilities to make this system rigid, and for the mechanical and structural systems to be sound.
What I am less confident in, and is the problem we are currently facing, is the electronics and wiring system. We plan on using NEMA34 motors to dual drive the gantry along the Y-axis, to drive the Z-axis assembly (cutting arm) along the X-axis, and the Z-axis ballscrew itself. We will use NEMA23 motors to drive the B/C axes on the head itself in which the spindle sits. That gives us 6 axes to control, and I'm unsure of what control board we will need. I have done some research, and found a 6 axis control board, but I'm worried that this won't allow for the 3 axes + the slaved axes for the gantry, as well as the 2 rotary axes. Does anyone have any experience with this, or know if this will work? We are going to use Mach 3.
In summary, I have a few questions for those of you who've done this before:
- Will the 6 axis control board I've posted a picture below handle what we are trying to achieve?
- Suggestions for spindle head (air cooled, water cooled, 2.2kW?, etc.). Completely newbie to this part of the design.
- Software for generating the toolpath and gcode for 5-axis capabilites (I've heard cnc-toolkit, AutoDesk Fusion)?
- Other tips for the electronics side of things; again, complete newbie with this aspect of the design
Any constructive criticism or suggestions are welcome and appreciated. This is turning out to be a huge endeavor, but I'm enjoying it and I believe that the final product will pay off. I've posted a few visuals from our current design iteration to hopefully help clear things up.
Note: the models are very preliminary, most of the mates and geometry are there, but some components like the rack and pinion drive are not in their final places.
Please help if you can!
- Scott
