DEAR ALL ,
my cotroler fanuc omc can't run in helical interpolation , please help me .
best regards .
DEAR ALL ,
best regards .
You must have an older machine cause I think all the newer ones can do helical interpolation. So you can't do it? Find a different way to do your Bores then. You can drill a center hole for tool clearence then send your cutter in there and circle interpolate the bore. Come back to center and do it again till you get to depth. Then send in a finish tool to bring it to size using circle interpolation. Short of buying a new machine you'll never get helical interpolation on that.
