586,069 active members*
3,703 visitors online*
Results 1 to 6 of 6
    Sep 2014
    123
    HeeksCNC doing CRAZY stuff...
    Ok so i thought i had it figured out, imported a DXF file, generated all the operations and toolpaths, looked great, ran the simulation, perfect... Loaded the gcode into Mach3 and got this crazy path info...
    Why is it doing this????? It puts all these crazy circles over the part in the background.
    Re: HeeksCNC doing CRAZY stuff...
    its just that one program uses absolute I/J coordinates and the other relative ones.
    You can change this in Mach3 somewhere.
    Christian
    My CAM Software and CNC Controller: www.estlcam.com
    Sep 2014
    123
    Hmm... I spent about three hours trying to get the toolpaths to show up right in Mach3, if there is a way i sure can't find it.
    I would love to get HeeksCNC working right but at this point i'm starting to consider saving up for MeshCam unless i can get it work flawless every time. Heeks is just a ton of work to get even the simplest part to process into gcode so far.... Unless i'm just doing it wrong?
    Sep 2014
    123
    Now i'm gonna have to download and check out estlcam.... LOL
    Why is there SOOOO many CAM programs... Its mind boggling.
    Jul 2014
    1
    I had this happen to me as well. I changed I J to incremental under General Config screen in Mach 3. Re-loaded the g-code and the crazy circles were gone.
    Sep 2014
    123
    I gave up on Heeks, seemed like a neat program but for the stuff i do MeshCAM is so much easier. Open file, process, send to machine. Maybe ten mins to prep for making a part at the most. I'm thinking MeshCAM is going to be the way to go on this.
  1. HeeksCNC.. STL How-To???
    By kb0nly in forum OpenSource Software
    Last Post: 09-18-2014, 11:32 PM
  2. Zig Zag instalation on HeeksCNC?
    By Abcdeflijus in forum Uncategorised CAM Discussion
    Last Post: 11-12-2013, 07:08 PM
  3. Mach3 tuning (cuts small stuff fine, but is off on big stuff)
    By jdbaker in forum Mach Software (ArtSoft software)
    Last Post: 03-15-2007, 05:30 PM
  4. The crazy stuff you used to do
    By Steve@Reliance in forum Community Club House
    Last Post: 06-26-2006, 05:40 AM
  5. welding thick stuff to thin stuff - need advice
    By cross6 in forum Welding Brazing Soldering Sealing
    Last Post: 01-13-2005, 08:39 AM
