587,354 active members*
4,759 visitors online*
Results 1 to 2 of 2
    Nov 2007
    79
    HEAD STOCK LUBRICATION LOSS
    hi all
    i have an alarm no 1038 (head stock lubrication loss)
    the machine is
    ALPHA 1400 XS 600 Group
    The controller: COLCHESTER –HARRISON GE Fanuc ALPHA X Series
    i checked the oil level in the tank for slides lub and it's full
    also the oil level in the gear box is full
    nothing helps in the manual
    thanx in advance for any help
    Apr 2010
    45
    chances are that you moved the machine recently and you need to change the two phases in order to correct the phase .
    I f you open the back you will see two hoses going to the spindle the big hose is the return and the small hose goes through a filter and supplies oil to the spindle bearings
  1. Lagun FTV-2 Gear Head lubrication point location
    By ab4td in forum Knee Vertical Mills
    Last Post: 12-14-2010, 05:33 PM
  2. J Head Lubrication
    By pearldiver in forum Bridgeport / Hardinge Mills
    Last Post: 07-11-2009, 07:10 AM
  3. Head Stock alighment
    By leeharrysouth in forum Shopmaster/Shoptask
    Last Post: 11-11-2008, 08:48 PM
  4. Mazak QT-20 HP Alarm Head Lubrication
    By Carnedude in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-22-2008, 09:06 PM
  5. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
