587,782 active members*
2,831 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Having trouble figuring out the toolpath here, has a dovetail>
Results 1 to 7 of 7
    Jun 2009
    33
    Want to rough with a 1/2 inch endmill and dovetail with a 3/4 60 degree dovetail bit. Not sure if contour or pocket path to choose. verify always comes out wrong.
    Attached Files Attached Files
    Dec 2008
    3136
    To do just the dovetail
    2D_contour- 1/2" endmill rough , use top line,
    2D_contour- 3/4" dovemill finish, use base line of dovetail form,
    extend the lead in / ous of the lines by at least 1/2 the cutter
    Jun 2009
    33
    problem is it wont let me pick that top line. I designed the profile and extruded it. Seems like I may be missing a step to let the lines be chosen individually.
    Dec 2008
    3136
    What version Mastercam ?
    Jun 2009
    33
    x3
    Dec 2008
    3136
    You can create wireframe geometry from your model for the 2D operation
    - suggest you select a new level and color
    From top toolbar
    >create
    >curve
    >create currve on one edge ( move your mouse over the vertices and select the ones you want )
    edge can be of a surface or solid
    these then can be selected in your machining op
    Jun 2009
    33
    Thank You. Thats great and that did the trick.
  1. figuring shrinkage
    By spock in forum Moldmaking
    Last Post: 06-14-2008, 04:31 PM
  2. Need Help on Figuring Speeds
    By mgandy02 in forum DIY CNC Router Table Machines
    Last Post: 01-12-2007, 04:59 PM
  3. Need Help Figuring Out What Servos I Need!
    By CATCH22 in forum Servo Motors / Drives
    Last Post: 09-28-2006, 06:48 PM
  4. 2D toolpath, beginners trouble
    By SVM in forum BobCad-Cam
    Last Post: 07-13-2006, 02:18 PM
  5. Figuring out VMC air CFM needs for an air dryer?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2006, 05:17 AM
