587,913 active members*
3,903 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Having trouble with capscrew counterbore in brass
Results 1 to 8 of 8
    Jan 2008
    6
    Greetings. I recently purchased a CNC router, and one of the projects I am working on requires a counterbore for a capscrew in 1/4" thick brass bar. I'm machining with a counterbore of roughly 3/16" (pilot) and 5/16". I set my spindle speed at about 3500 RPM and I slowed my plunge rate right down to the slowest setting. The steel tool that I used went about 1/16" in and then started to deteriorate. I don't know if I'm just trying to do something that's not meant to be done with a CNC router, or if maybe I was steered in the wrong direction by the company that sold me the tool.
    Any advice would be greatly appreciated, as this is the final step before I can test my product for production and then begin selling it. If you think it's just the tool, any reccomendations of suppliers that sell counterbores, preferably with dealers in Ontario, Canada? Thanks in advance.
    Dan
    35538
    I'm guessing your cutting it dry? You probably need a lot of coolant to do that.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2007
    355
    Sounds like the tool is overheating. Try a spindle speed of 1000 rpms, and a feedrate of .013 feed per rev. (13 ipm).
    If possible, use a lubricant (WD-40, mineral oil or coolant).
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    4826
    IMO, counterbores suck. The few times I've used them on manual machines, they seemed to require a bit of man-handling, like to the point of being a bit rammy with them. The requirement seems to be high feedrate to induce lots of cutting pressure.
    The gentleman's method of doing a counterbore is to interpolate a circle with the cnc.
    Brass can be difficult to work because it wants to hog onto positive rake tools (like drill type counterbores). And a dwell mark on brass serves to harden that spot locally. The harder spot then requires that you boost the feed pressure to break through, which inevitably happens, then the tool gets a good bite immediately into the soft material beneath, and bam, it hogs in and rips the part out of the vise
    Mar 2007
    32
    Quote Originally Posted by HuFlungDung View Post
    Comment made me laugh. I like the term "rammy". Going to have to remember that one.
    Jan 2008
    6
    Thanks a bunch
    Thanks for the speedy replies. There is a lot of really helpful information and I'm confident that I can now get this going. And if I don't, you'll all be the first to know. Well, maybe my wife will know first due to the excessive amount of swearing that will follow any further problems . Thanks again everyone!
    Dan
    Oct 2005
    1237
    WAY too fast with a counterbore. Counterbores like speeds below 450rpm.
    Sep 2008
    1
    I also have a flatbed CNC.
    Never had problems machining brass. Use only engravers brass, it is a lot harder and self lubricating so no need to lubricate. Any other brass is too soft and will bind to the cutting tool giving a poxy finish, tool breakage, and swarf build up on the component.
    Hope this helps,,,
    Jon (Cut It Out) Australia
  1. How do you counterbore?
    By cyclestart in forum MetalWork Discussion
    Last Post: 05-03-2008, 05:26 PM
  2. Weld Brass to Brass
    By piratesover40 in forum Welding Brazing Soldering Sealing
    Last Post: 03-04-2008, 01:02 AM
  3. Counterbore/drill combo
    By ossito in forum CNC Tooling
    Last Post: 08-07-2006, 06:58 PM
  4. Brass...why?
    By creative_mind in forum MetalWork Discussion
    Last Post: 05-25-2004, 06:27 AM
  5. Where to buy Brass?
    By NeoMoses in forum MetalWork Discussion
    Last Post: 10-06-2003, 02:35 AM
