587,158 active members*
3,096 visitors online*
IndustryArena Forum > CAM Software > Vectric > PhotoVCarve and VCarve Pro > Having some issues with Vcarving.
Results 1 to 14 of 14
    Apr 2013
    9
    ok.....so i'm working on a project and through Aspire->Lcam->Mach3 have successfully made this.
    2/23/15 - 1.mov - YouTube
    Later I had made this in Vcarve.
    *see attached .DXF
    After RTFM i found out how to save as gcode using CNCRP's recommended MACH2/3 post. I ran the code and the Z dropped down about 3/4 into my spoil board which was properly zero'd. Then ramped up and over and began to properly cut the vcarve path that i had intended to, but did so roughly .125 inches ABOVE the spoilboard. Then when it went to the rapid height it dropped down and cut that out. I'm not ashamed to admit that it's probably something unbelievably simple that i overlooked but my brain is TOAST!!!!!! I've gotten this far on my own and i hope someone can help me out ! Thanks
    Apr 2013
    9
    Re: Having some issues with Vcarving.
    My best guess is that it is something in Mach 3. Something with IJ ? I even loaded the "open" sign sample dxf and posted it the same way. When i ran it i got the same results.
    Apr 2013
    9
    Why does Lazycam not recognize the vacarve toolpath? Instead it just profile cuts on the vector...
    35538
    You can't load toolpaths into LazyCAM. I'm assuming you loaded your .dxf file into LazyCAM.
    The .dxf file doesn't tell anyone anything about your problem. You should post the g-code, and the V Carve Pro file.
    Without that information, all I can do is guess.
    And why are you going from Aspire to LazyCAM??
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2013
    9
    I am completely new to this but know enough to get started. obviously i need to read a lot more. Here is the Gcode and pardon my ignorance.
    Apr 2013
    9
    And yes i meant .DXF into lazycam and i'm not sure why i'm using it either as i've found out it's not too great.
    edit* i'm guessing now after reading more that i don't need it?
    35538
    Are you sure that your Z axis is not backwards? Z+ is up, and Z- is down.
    Your g-code looks correct, but from what you're describing, you have your Z axis backwards.
    Gerry
    Apr 2013
    9
    That's exactly what i was thinking but it sounded too crazy. I have a dual drive gantry and got X and A backwards but that was an obvious and easy fix. If the z is opposite would i have to change all of the values in Gcode for z to - instead of positive or vice versa ? or set it in Mach3 ? Thanks again for your help.
    Edit* the video shows everything working fine the first time posting from lazycam. If i post from Vcarve; i get the possible polar opposite Z weirdness. It might be best to get to the shop and shoot a video of it actually happening. I know i zero'd the bit to the top of the board but the first thing it does is plunge really deep and then ramp up diagonally above the work area leaving only the rapids.
    35538
    Just jog up and see which way the DRO is counting. It should count up as the axis moves up.
    Gerry
    Jan 2007
    1795
    Gerry
    he has a very deep point in the logo
    I think for the logo he should set depth limit..
    the bit sink 5 times.. and deepest point is 0.5759
    mightbe that was what he seen weird..
    Apr 2013
    9
    That's about right. It happens immediately; but only once. I'll be in the shop tomorrow and take a video and now that I remember, when I jog the Z up I have to hit page down and i assume it should be page up.
    Apr 2013
    9
    Apr 2013
    9
    ALRIGHT !!!!! after many hours of reading and head scratching i can happily report that it was a stupid error that was right in front of my face. what i did was go into Mach3 ->config->homing/limits and reverse the Z. I ran that same code and all worked out well. Thanks
    35538
    I told you that 3 days ago.
    Gerry
  1. Got tired of Vcarving
    By Trotline in forum BobCad-Cam
    Last Post: 03-09-2016, 05:24 AM
  2. VCarving tutorial?
    By John Coloccia in forum MadCAM
    Last Post: 04-01-2013, 02:12 AM
  3. VCarving Masking question
    By jburks in forum DIY CNC Router Table Machines
    Last Post: 05-08-2012, 03:32 PM
  4. VCarving problem
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 11-25-2005, 02:47 AM
  5. What VCarving tools are you using?
    By PEU in forum Vectric
    Last Post: 11-19-2005, 10:38 PM
