Just recently got this intermac and we had to replace the spindle on it. When we turn the control on it gives us a spindle drive failure error. If anyone knows anything about this all help is appreciated. thanks
I had similar issues. I found there are 3 thermal relays in the back of the "tower". One of which Intermac doesn't make anymore so you will have to source it elsewhere. The cause was carbon buildup on the contacts inside the relays.
Hope this helps.
