587,693 active members*
3,558 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Has anyone ever had or heard of a.........
Results 1 to 7 of 7
    Jan 2005
    66
    Bad stepper right out of the box??? I had bought three steppers and swapped out some 125 oz/in steppers for these 258 oz/in MCG steppers,,, upon turning on the power, the X axis control on my Xylotex board promptly shorted out. During the time the board was out for repair, I've rechecked the wiring, checked for shorts, checked amp draw per phase,,, even hooked them up to a 12Vac transformer and didn't find anything peculiar. I got my board back yesterday, and hooked it all back up tonight,,,,, All three axis were running as they should, no heat, no pops, and most importantly,, no smoke. Loaded up a small gcode file, and Found I no longer had power to my X axis...... All of my wiring is soldered and heatshrinked, and the Molex connectors are crimped, and soldered.
    Meanwhile...... :drowning: :drowning:
    Jun 2003
    3312
    Did you set your current limit on your xylotex board?
    Phil
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jan 2005
    1695
    Something you should never do is to connect/disconnect the motors when the power is applied. This can fry the chips.
    Jan 2005
    66
    Limit control was set per instructions,,,, and the motors were not disconnected while under power,,, My friends occasionally poke fun at me for always reading the instruction manuals on anything I use.
    Jan 2005
    66
    Update... when I got home from work and dug into my mystery, I now discovered that one of the coils is shorted out to the case,,,, on the mill I was getting .5 ohm,, Now 2.5 ohms,,, Needless to say that did not show up the first time when I let the smoke out. Mystery solved. Still, I have one blown axis on my controller, glad I went with a 4 axis drive, It would have been even better to gone Gecko!!! Can't wait for the Vampire to be avaailable.
    35538
    Quote Originally Posted by Mac T. Knife
    Why would a blown Gecko have been better? A G201 would have blown just like the Xylotex did. Hopefully the G204 won't be too much more money when they are released.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2005
    66
    Quote Originally Posted by ger21
    Well,,,, Having a 4 axis board,, to fix one axis, I also have to send in 3 good drives at the same time,,, Geckos,,,,, just the one.
    I read one of Marris'es earlier reports on the Vampire drive,,,, an intentioonal dead short on both outputs, and it just shuts down,,,, wakes back up after a second, and shuts back down repeatedly until you fix the fault.
  1. Anyone heard of this controller?
    By noid in forum Servo Motors / Drives
    Last Post: 05-08-2009, 04:44 PM
  2. Anyone heard of Simwork
    By CBNDude in forum MetalWork Discussion
    Last Post: 03-16-2005, 06:38 PM
  3. Has anyone heard of cncxyz?
    By noid in forum DIY CNC Router Table Machines
    Last Post: 09-28-2004, 12:20 AM
  4. AMSOIL ever heard of this Oil what do you think about it?
    By WallCrawler in forum Community Club House
    Last Post: 06-04-2004, 10:09 PM
  5. Has anyone heard this?
    By brtlatjgt in forum OneCNC
    Last Post: 11-24-2003, 04:00 AM
