Spindle:
Using control panel pressing cs should start my spindle at 25 rpm.
It starts a 0 using my speed override. I can get the rpm's only to 10.
Is this a parameter problem, if so can this problem be fixed?
Spindle:
Does it go higher than that if you enter it in MDI mode?
Using the control panel and pressing CW or CCW starts my spindle at 0 using my speed override. Each push of the button should increase my spindle RPMS by 25 RPMS. First push of the button increases it to 10 RPMS and will not go any higher.
MDI mode works fine. I think the override is not working correctly?
