Hello, I do not have a lot of programing experience, and I have an issue with a program, for a Hardinge Conquest St225-B machine. I believe the program was created on Part Maker. The program works on the machine, but I cannot get the thing to repeat. It ends up pausing after the slotting cycle. It almost seems like there is an invisible M0 in the program. After this stop the program will part-off and start the program again. I have to make 1000 + parts and right now I'm pushing the Cycle Start button once per part. I included the problem area of code. I looked through the thing and could not figure out what is causing the problem. I would really appreciate if someone could tell me the problem or get me on the right path to fixing it. Thanks.
H1
O2260 (1/19/2014)
(HARDINGE SST POST PROCESSOR VERSION B8.0)
(COLLET RECHUCK)
M900
G0 G28 U0
T1414
G0 X0.35 (STOCK + CLEARANCE)
G97 S3000 M13
G1 G99 X-0.02 F.002
G97 S500 M13
M21
M93
G4 V.5
G300 Z1.5
G50 Z0.6526
M22
M94
G4 V.5
G0 X1.25
G28 U0 T0
M901
M1
(PROCESS 1 FACE)
M902
G28 U0
T1515 (80-RIGHT KM TURN .002 )
G97 S3000 M13
G99 G0 X0.286 Z0.
G1 X0.246 F0.002
X-0.004
M903
(PROCESS 2 MAIN TURN TURN)
G0 X-0.004 Z0.
G1 X0.2277 F0.004
X0.25 Z0.0112 F0.0005 (CHAMFER)
Z0.0812 F0.002
X0.2688 Z0.0906
G0 X0.35 Z-0.05
G28 U0
M904
M1
M5
(PROCESS 10 SAW SLOT 1)
M905
G28 U0
T0303 (.025 SLOT SAW)
S2000 M53
B0 Y-0.225 Z-0.475
G98 X0.35
G1 X-0.04 F75.0
Z-0.345 F5.0
Y0.225 F5.0
Z-0.475 F5.0
G0 X0.35
M906
(PROCESS 6 SAW SLOT 2)
M907
B0 Y-0.225 Z-0.475
G98 X0.35
G1 X-0.01 F75.0
Z-0.345 F5.0
Y0.225 F5.0
Z-0.475 F5.0
G0 X0.5 M55
G0 Z-.05
G28 U0
M908
M1
M24 (C-AXIS OFF)
G18
(PROCESS 7 BACK TURN) <<<< This is where the machine stops.
M909
G28 U0
T0505 (SANDVIK MABR 3010)
G97 S2000 M13
G99 G0 X0.29 Z0.05
G1 X0.25 F0.001
X0.1342
Z0.1779
X0.1 Z0.195
G0 X.350
G28 U0
M910
M1
H2
O2260 (1/19/2014)
(COLLET RECHUCK)
M900
G0 G28 W0
M901
M1
(PROCESS 1 FACE)
M902
G0 G28 W0
M903
M904
M1
M905
G0 G28 W0
M906
M907
G0 G28 W0
M908
M909 <<<<< Stops here.
G0 G28 W0
M910
(M1)
