587,395 active members*
3,593 visitors online*
Results 1 to 8 of 8
    Dec 2004
    13
    Hard Coat Applicator for EPS
    Now, you can use the same Hard Coat (Fast Cure) as used by the big boy shops. The FasT Kick Combo Gun/Proportioner allows you to spray and encapsulate the EPS. The Unit uses Disposable cartridges, no wast, no mess no fuss. This Sprayer was designed with the Novice in mind, you spray perfect ratio or you do not spray. No waste. No need for large warehouse space. This is the same Polyurea HardCoat used by Major Theme Parks, Architectural Colum MFG and Signage People. Feel free to ask any questions.
    Fast Kick Gun and Products
    Mar 2005
    187
    Where can this be gun be purchased?
    I Looked up and down the website that you provide but all I see is pictures.. perhaps I'm overlooking something?
    Thanks,
    Drew
    Dec 2004
    13
    This is New Web site with info
    This shows more about the Spray Gun Proportioner but highlights only the Bedliner PolyUrea.
    Thanks,
    Tom
    http://tom.ieasysite.com/
    Jan 2005
    66
    Again,,, Where can the gun and Polyurea HardCoat cartridges be purchased??? We are looking into cutting foam,, and that's alot cheaper than the production units.
    May 2004
    8
    Gun and Polyurea HardCoat cartridges
    These items can be purchased from:
    Diana Hammond
    Chemical Design Corporation
    906 HD Atha Road
    Monroe, GA 30655
    Phone: 800-578-8555
    Fax: 770-207-4535
    I purchased my gun and material from Chemical Design; they are on the ball concerning info, shipping and keeping in contact with the customer.
    Dec 2004
    13
    Hmmmmmmmmmm
    The Gun sells for $570.00, the Hard Coat is $25.98 a Cartridge (6 Cartridge to a case) All Shipping is 3 Day UPS. Glad to hear the daughters are following in their moms footsteps, she was a great lady and friend.
    Dec 2004
    13
    Oh, new website is SprayMaxliners.com
    Dec 2004
    13
    Please check Home | EPS HardCoats
    Thanks,
    Tom
  1. A2100 Hard Disks
    By tricky in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-21-2018, 08:33 AM
  2. High Speed Hard Milling
    By MachineSMM in forum Hard / High Speed Machining
    Last Post: 03-28-2006, 01:31 AM
  3. A2100 Cincinati Hard Disks
    By tricky in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2005, 02:03 PM
  4. hard turning carbide
    By bonz in forum MetalWork Discussion
    Last Post: 01-21-2005, 06:24 PM
  5. Printing on hard surface tile?
    By jeffterm in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-01-2004, 11:32 PM
