So after lots and lots of research, i'm finally getting the ball rolling on my CNC conversion on my HAFCO HM48 geared head machine. After a lot of research i setteled on the HM48, i had a few key aspect it had to have, Single phase (230v) and a geared head. and within my price range.
Machine details.
Table Size 820 x 240mm
Column Type Dovetail
Longitudinal Travel (X-Axis) 540mm
Cross Travel (Y-Axis) 185mm
Vertical Travel (Z-Axis) 410mm
Type of Slides Dovetail
Spindle to Table 490mm
Quill Travel / Diameter 120mm / 75mm
Drilling Capacity 31.5mm
End Milling Capacity 28mm
Face Milling Capacity 80mm
Spindle Speeds Vertical (steps/rpm) 6 (95-1600rpm)
What I'm about to purchase just hoping for some feedback.
X,Y, & Z stepper drives are going to be NEMA 34 1200oz drives direct for x&y 2-1 reduction on Z axis i will not be motorizing the Quill leaving it standard.
Drivers
KL-870D 70vdc/7a Digital 32bit DSP based
Breakout board
C11 from automationtechnologiesinc.com
I plan on getting the 4 axis up and running later down the track.
Im not to bad on autocad, so i might stick to that, i have decided on mach3 as the driving software - but yet to decide a cam software.
Ive taken all the measurements on the new ball screws and just put the order in for 2505 with bk-bf17 ends.
Im really hoping i can get any feedback that will help before i order the drives, or even better if there is any one local to Mackay QLD that has done a CNC conversion id be very appreciative to talk to someone local, learn as i go!
