587,306 active members*
3,794 visitors online*
Results 1 to 5 of 5
    Jan 2007
    61
    Haas trunnion tool change
    We just got a new Haas 160 trunnion running it in a vf2 at every tool change the trunnion goes back to zero. Is there a parameter for this to keep it at 90 and not go back to zero? Thanks
    Mar 2010
    1852
    Re: Haas trunnion tool change
    Post your code.
    Mike
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Jan 2007
    61
    Don't really need the code let's say I put trunnion at 90 deg manually then do a tool change in MDI the trunnion will go back to zero or are you refuring to tool change code
    Oct 2005
    9
    Anybody know this one?
    Oct 2015
    32
    Hit the PARAM/DGNOS key, type in 269 and then hit the down arrow. The fourth line down should read ZERO AXIS TC. If this is set to a 1, the axis will go to zero every time a tool change is commanded. If this is set to 1, change it to zero and let me know if that fixes the problem.Make sure you don't run the tool changer double arm into the trunnion when you leave it at 90 degrees.
  1. Haas GR510 tool change locked
    By PD-CNC-GUY in forum Haas Mills
    Last Post: 05-03-2014, 05:11 AM
  2. Spindle Popping during tool change? HAAS
    By AllenGauge in forum Haas Mills
    Last Post: 12-10-2011, 03:48 PM
  3. Haas VF-0E Tool Change Motor
    By MichaelK in forum Haas Mills
    Last Post: 10-25-2011, 05:25 PM
  4. Trunnion setup change in my post
    By deon in forum Post Processors for MC
    Last Post: 05-04-2011, 11:54 PM
  5. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
