587,489 active members*
3,151 visitors online*
    Sep 2007
    2
    HAAS PROGRAM BACKUP ?
    I am looking for help in transfering my programs in my HAAS machine from the machine to a computer as a backup. I can transfer them 1 at a time using the SEND RS232 but with 300+ it will take some time.
    My HFO suggested that I use the advanced editor.
    Edit - F1 - I/O - SEND RS232 - (SELECT PGMS) - WRITE
    This seems to work at the control but the problem is at the PC. Everything is received as one big file. I will have to cut & paste each program. I would be better off sending each one by itself.
    I do not have floppy drives or USB on this older machine.
    I have Windows XP pro as the operating system.
    Any ideas?
    Apr 2006
    133
    Split ALL into separate files
    I have a program written in Visual-Basic that takes your "ALL" file and splits it into separate files and save them to your hard drive with a "Long Name" if your customer and drawing number are embedded in your program text.
    If you would post an example of your first 2-3 lines of your programs I can make sure it will work and then Zip it into a folder and either post here or send it to you by E-mail
    Sep 2007
    2
    HAAS PROGRAM TRANSFER SAMPLE
    Here is a sample of one of the program beginnings.
    O5210 (D-60420-2)
    (KNIFE SLIDE TOP)
    (12/06/2001)
    (OPERATION 50)
    (SET UP AND BOLT TO FIXTURE)
    (T1 = CENTER DRILL)
    (T2 = 5/16" DRILL)
    (T3 = 3" ISCAR MILL)
    (T4 = 1" HSS END MILL 2" FLUTE)
    (T5 = 30 DEG. DOVETAIL CUTTER)
    N3 M98 P9998
    T3 M06 (3" ISCAR MILL)
    G00 G43 H03 G54 G90 X-1. Y-0.5 Z3.
    S2500 M03
    M08
    All programs also end with:
    M30
    My email is [email protected] for this.
    Thanks.
    Thank you
  1. Trying to load program using Cimco into a Haas
    By Robert Timby in forum Haas Mills
    Last Post: 01-31-2017, 06:51 AM
  2. Example CNC machine Setup Sheet + program backup
    By lug_wrench in forum DNC Problems and Solutions
    Last Post: 12-28-2015, 06:37 PM
  3. backup program of T1 and M1 to PC
    By vpkurt in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2007, 08:15 AM
  4. TL1 Haas intuitive program restarts?
    By elaganis in forum Haas Mills
    Last Post: 02-02-2007, 09:06 PM
  5. haas program question
    By cncsdr in forum Haas Mills
    Last Post: 09-17-2005, 06:17 AM
