587,501 active members*
3,162 visitors online*
Results 1 to 7 of 7
    Aug 2008
    28
    Haas Mini Mill Pneumatics
    HELP!! I have a Haas mini mill. One of the guys in the shop took apart the Air regulators in the back of the machine- the incoming, the low pressure regulator,and the automatic lube manifold and valve. I was assured that he knew exactly how to put it back together, well, guess what!!! any pictures,makeshift diagrams or info would be GREATLY APPRECIATED!
    THANKS!
    927
    How about this..hope it helps..sorry a bit dark back there..
    Attached Thumbnails Attached Thumbnails IMG_0656.JPG   IMG_0657.JPG   IMG_0658.JPG   IMG_0659.JPG
    Aug 2008
    28
    Thanks, I hope that gets me started!
    Mofified Pictures
    I lightened up the pictures a little bit. It may help on seeing more of the details.
    Attached Thumbnails Attached Thumbnails IMG_0656a.jpg   IMG_0657a.jpg   IMG_0658a.jpg   IMG_0659a.jpg
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
    Aug 2008
    28
    These pictures have been extremely helpful THANKS!!!
    I still am looking for any idea where the low pressure regulator is hooked in. It is behind the panel where the regulator is mounted, but any type of description would really help. Thanks again!!
    927
    Couple More shots
    Attached Thumbnails Attached Thumbnails IMG_0660.JPG   IMG_0661.JPG   IMG_0662.JPG
    Aug 2008
    28
    Question
    Thanks, Got it back together,but still getting the low pressure alarm that I was getting originally. Changed the regulator,and have enough air pressure, but still no luck. does anybody know if there is anything that could be blocked elswhere on this machine???? Thanks again for the help!!
  1. Haas Mini Mill Maintenance
    By slatern44 in forum Haas Mills
    Last Post: 01-04-2020, 05:11 AM
  2. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  3. haas mini mill
    By johnmckeown in forum Haas Mills
    Last Post: 02-19-2009, 05:26 PM
  4. Haas mini mill
    By pyroracing85 in forum Haas Mills
    Last Post: 05-12-2008, 01:33 AM
  5. HAAS Super Mini Mill
    By Ford25 in forum Haas Mills
    Last Post: 09-07-2007, 02:01 PM
