587,729 active members*
3,303 visitors online*
Results 1 to 2 of 2
    Nov 2018
    1
    haas hrt210b and hrt160.
    Haas vf4 4rth axis is brushless. the 210b works perfectly and after replacing mother board, 210 works perfect. however now when trying to use a hrt160 with a brushless converter i get Alarm 106. Hrt 160 works fine in another machine without brushless converter. with that being said we replaced brushless converter with a brand new one, and still get same error. haas tech was here for 4 hours and could not resolve issue. before motherboard was replaced had no issue using brushless converter with hrt160.
    Dec 2004
    126
    Re: haas hrt210b and hrt160.
    Alarm 106 ? servo error to large?
    there is a setting to adjust it in the control.. I just played with it on my machine tell i got it working .. if you don`t find info on it . I can look at try and find my paper for it .. I have to change it every time I swap out my HRC210`s ...
  1. Haas HRT160 Won't home
    By Stew985 in forum Haas Mills
    Last Post: 12-26-2017, 03:31 AM
  2. HRT160 Can't home
    By JohnJW in forum Haas Mills
    Last Post: 09-17-2013, 03:37 PM
  3. MiniMill 2 with an HRT160
    By obiwon in forum Haas Mills
    Last Post: 03-10-2012, 01:32 PM
  4. HRT160 3 jaw chuck? Tooling bar?
    By helocat in forum Haas Mills
    Last Post: 01-11-2012, 07:03 AM
  5. HRT210B Mountinig -- Need CAD File
    By jmcglynn in forum Haas Mills
    Last Post: 05-28-2009, 10:05 PM
