587,625 active members*
3,167 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas facemilling:coolant yes or no
Results 1 to 17 of 17
    Jan 2007
    46
    I am the the proud owner of a new Vf2. On my old 5 hp toolroom cnc mill I always facemilled (3" diameter) dry because when I added flood coolant it was a horrendous cleanup!! Can some of you other more experienced VMC operators tell me do you normally use flood coolant with face mills? My main materials that I machine are 6061, mild steel(1020) and A2 tool steel.
    Thanks in advance for any advice.
    Joe Simmers
    Simmers Machine
    Dec 2005
    439
    I would use coolant but what type of inserts are you using in the face mill?
    I'm not lazy..., I'm efficient!
    HAAS GR-408
    Jan 2007
    46
    It is a newer style Iscar facemill with 6 inserts, not sure of the
    insert numbers right now but can find out tomorrow if it makes a difference.
    I also have a 2" one with 4 inserts.
    Thanks, Joe
    4826
    I'd say "yes, coolant for aluminum", and "no, dry for steel". I just find that often I don't get good insert life when using coolant on carbide when cutting steel, so I run it dry with air blast to move the chips.
    There are so darn many grades of carbide out there now, there may be something that can tolerate thermal stress/shock that I don't know about. I usually keep a stock of moldy old inserts on hand, so I may be well behind on the latest and greatest insert grade.
    Jul 2005
    12177
    Like Hu says; aluminum flood and steel dry. With flood on Aluminum you can take advantage of the extra power and speed you have in the VF2. I suppose with steel if you could really flood, that is have the cutter totally immersed in coolant 100% of the time then it would work because there would be no thermal shock. But I can't figure out how this is possible.
    Aug 2005
    578
    Same here. Flood alum, as much spindle as your machine has. Steel, Dry at 200sfm in most stainless. I have a general rule of thumb, in steel, anything above 500sfm, I run dry. Works well for me
    Jul 2006
    7
    vf-2 30hp 3" face mill mitsu 875 rpm
    33.0 feed rate .187 depth cut @40 % on spindle mat 3x3 steel cr full ingagement of 3" width no problems
    Jan 2007
    35
    My preference - cut dry
    From what I've seen, I would cut dry but with airblast to get rid of the shavings (They're a killer).
    Jan 2007
    46
    Quote Originally Posted by weaston View Post
    How do you hook an airblast up to your mill? How is this plumbed on the vf2?
    Anyone with a detailed pic I would love to see it.
    Thanks, joe
    Oct 2003
    127
    the insert you are using and the material you are cutting will detemine wethere you want air, coolant or nothing.
    if you have an enclosed machine you should atleast use air to evacuate the chips so you don't "recut" them.
    look at the manufactures recomendations for the insert and material.
    if you use coolant and you shouldn't have, your insert will suffer from thermal shock from the heat generated at the point of contact and the coolant quenching the heat and the edges won't hold up very well.
    i have 2 vf3 ss and puchased both with an air gun option all mounted to the head with m function on/off.
    have older machines we just plumbed an air line over the top into the machine and hook up a valve to the end of the line pointing towards the spindle.
    Nov 2006
    154
    You should be able to get a techinical guide from your insert supplier/salesman free of charge if he/she wants to maintain your business. I have gotten a full set of Seco tech publications and a huge one from Ingersol, both from the salesman.
    They contain speed and feeds for all the tooling they make including info about wet or dry cutting. I cut a varity of steels, mild, tool, stainless, alloys, super alloys and have been able to find the information I've needed in these FREE books!
    Steve
    Feb 2007
    1
    Air Blast
    Quote Originally Posted by joesimmers View Post
    Thanks, joe
    I used a solenoid valve connected to a plug in place of the coolant pump plug and a LocLine nozzle. That way when the machine calls for coolant I get an air blast instead.
    John
    Jun 2007
    19
    i use coolant on alum and softer steel (4140 ann, crs) otherwise i use air
    Jun 2007
    31
    Run Dry unless your finish is not up to par.Sometimes running dry gives that slight bumpy feel from the chips getting dragged across the material.If you cut wet make sure you are using the correct inserts for wet facemilling.
    Jan 2004
    539
    Man look at all those new tool holders...clean as a whistle...still got all of the warning stickers...Nothing better than a new machine
    I build a product that I cut in the 4th, its little over 40 inches long...starts out 82 lbs and almost 2 hours later is 45 lbs. All with a 3 inch face mill.
    I have tried everything coolant wise...but the best compromise...so far is turning the coolant on and off at different stages of the program. Doesn't sound like much and its a lot of editing but it saves about 5-7 gal of coolant a day
    Jan 2004
    201
    coolant pump plug
    be careful, the coolant pump plug is likely 220 v single phase.
    i was going to upgrade to a larger pump and had trouble finding a 220v single phase pump that would fit.
    joev
    Jul 2004
    374
    For roughing aluminum, I run 3" and 4" facemills with an MQL airblast. (almost dry) Making big chips is the key. (go at least 0.008" per insert, and take a healthy depth, increase depth and chip load until you run out of horsepower)
    For finishing, NO QUESTION, run flood coolant. No matter what brand/grade insert I've tried, flood coolant is the ONLY way to consistently keep from dragging chips on a finish pass.
  1. Haas programmable coolant unit problem
    By xs-speed in forum Haas Mills
    Last Post: 01-30-2008, 06:54 PM
  2. HAAS VF-2 Coolant splashing
    By jtree83 in forum Haas Mills
    Last Post: 01-26-2007, 12:40 AM
  3. Haas VF2 Coolant Pump (Pressure) Question ...
    By Mike Braddock in forum Haas Mills
    Last Post: 06-09-2006, 01:54 PM
  4. Haas TL-2 Coolant ?
    By 100 in forum Haas Mills
    Last Post: 04-14-2006, 11:11 PM
  5. Facemilling: 300 cubic inches per minute
    By Rekd in forum Community Club House
    Last Post: 02-11-2005, 05:51 AM
