Originally Posted by
mattfurches
my haas 4th axis has gotten slack in it. if you dial it at zero and move it around a few times then home it to zero it will be off a couple thousandths every time. there appears to be some slack in the belt between the motor and the drive pully. Is there an adjustment on this belt or is it just a replacement item? would the belt being worn be enough to cause it to be out ? doesnt it have some way to verify position? sorry for the stupid questions but im new. HAAs vf2, Haas HRT 210 4th axis
If it is like the ones I've had, the motor is moved to add tension to the belt. I would try that first. After that you might need to adjust the worm to the worm gear. It may have lost some adjustment because of wear.
Like most indexers, it gets it's location off of the back of the motor itself, where the encoder is located. A loose pulley, belt, or gear adjustment will not be noticed by the encoder.
Mike
Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
