About 1 month ago i bought a H.F. 7 x 10 minilathe, model 93212.
The thing isnt shabby for the price, i have no complaints except that it has been giving me some problems when i go to use it.
When i start it i make sure the speed is at 0, and the forward/reverse is at nuetral before powering up. Sometimes it will fire right up no hassle as soon as i select a direction and start turning the speed dial.
Sometimes i will turn it on and the indicator light shows power select a direction and when i turn the speed up nothing happens, no noise or change in the power illumination.
I've simply turned it off before and then back on and it worked fine, sometimes i have had to unplug it and then turn it on to drain out the caps on the board then shut it off and plug it in and works fine. A few times none of that has worked and so i just turned it on and checked it not running then returned speed to 0 and direction to nuetral but left it on and walked away for 5 minutes and it works. Sometimes i'll do all this but with no luck and just try it the next day and it works just fine.
Once i get the lathe to run, it wont give me any problems, i can change the direction from forward to nuetral and wont give me any trouble as long as i leave the power on.
So far it hasnt given me any trouble if i turn the power off and turn it back on sometime later that day. I only use the power switch when im not going to be using it for a while and use the for/nuetral/rev switch when im not going to be turning for a short while as i have read that using the power swich to much can damage the board from the innitial power surge over time.
It seems that it only gives me problems when it sits a day or so.
I've put the machine on a surge protector that has a on/off switch on it and use that to turn the main power on and off instead of using the machines on/off. And that was after it started giving me startup problems so i dont think its the cause.
I have checked the power switch/ directional switch and pot to see if there were any loose wires and verify them working properly with a dig, multi. They are all good. I haven't dug into the board to check for loose wires on it yet but think im going to after i post this.
Any help on this would be awesome, i have a sterling engine to finish
Thanks, Shint.
