587,672 active members*
4,737 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Guitar Head and neck transition Solidworks Catia Mastercam
Page 1 of 2 12
Results 1 to 20 of 32
    Sep 2013
    131
    Help please, is there a magic tool to get this to blend. I have all the software listed. I used a neck that a guy made, and designed the head and need to blend it. I have the step file of both, or like this in the pic. Thank you all.
    May 2010
    132
    Re: Guitar Head and neck transition Solidworks Catia Mastercam
    Please specify what you mean by blend? and also share the solidworks models as well
    Sep 2013
    131
    Quote Originally Posted by VTPROS View Post
    Hi, thank you, this is all I need fixed, is this transition on the corners. I need it to look close to the real picture. Thank you.
    May 2010
    132
    the stp file had errors when opened in solidworks, well few ways to do that, first you need to redesign the handle as it's not well designed where they attach make sure it's just 1 edge attaching the two together and not very odd shaped as it is in the picture, for example the arm of the guitar needs to end with half a circle and the end of the guitar needs to be squared off, After that you can use the fillet feature in solidworks to get the look you're looking for. Hope this Helps
    Moussa Sleiman
    CEO / Instructor
    vtpros.net
    Sep 2013
    131
    Ok,thank you.
    Apr 2003
    3578
    You are look for one like this sir?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Sep 2013
    131
    That is perfect, I wish I knew the trick. Heel too please. Here is the step.
    Apr 2003
    3578
    How about I give you mine. Here is a STP file with Body and neck.
    Cadcam
    Sep 2013
    131
    Thank you, but I already have my style in production, but need my model fixed to cnc mill it.
    Apr 2003
    3578
    When I get a little time I will work on it for you.But today is preapring for then ext few days and some customer programming.
    Cadcam
    Sep 2013
    131
    Great, thank you.
    May 2006
    803
    "need my model fixed to cnc mill it."
    If you have one in production,
    then the transitions can be "reverse engineered/digitized" to perfection from your physical model.
    OR design something different
    Been doing this too long
    Sep 2013
    131
    That would be great, If I could scan it somehow and save as a .igs or .stp.
    May 2006
    803
    First draw the edges of the surface to be generated.
    2nd get the uv surface splines from the neck contour.
    Aw, nah this is too tricky to describe via text.
    IT is easy once you understand surfacing.
    I looked at the model provided, it is all there to do this.
    Sep 2013
    131
    Here is a cleaner model to work with. I tried it all in Catia, Solidworks and Mastercam. I guess I might have to draw lines inside the solid and create swept surfaces?. Thank you for your time.
    May 2006
    803
    Something like this. ?
    These are the surface normals, and
    UV splines and vectors that develop the curves
    that makes the solids to machine.
    I only know one way to do this surface. (the hard way)
    I checked the model provided and want to know if you really want
    the radii at either end or a more sophisticates curve profile?
    Sep 2013
    131
    Close to this would be perfect.
    Sep 2013
    131
    I wish I knew the trick. I have the head/heel and neck separated.
    May 2006
    803
    I did mine this way heel, headstock, neck contour, the last and trickiest hing is to blend "fillet"
    three separate zones in the cad model
    so that I can change the neck contour
    independent to the head/heel
    Sep 2013
    131
    Ok, thank you for the help and info.
Page 1 of 2 12
  1. Replies: 6
    Last Post: 03-25-2021, 10:01 AM
  2. Guitar neck and heel transition
    By poolrod2 in forum Mastercam
    Last Post: 09-16-2016, 01:07 PM
  3. Mastercam Guitar Neck Help
    By CyborgCNC in forum Mastercam
    Last Post: 04-14-2015, 12:47 AM
  4. Replies: 10
    Last Post: 02-05-2015, 06:37 PM
  5. OYE! Need help on 3D neck transition
    By wbegg in forum Musical Instrument Design and Construction
    Last Post: 10-06-2011, 05:37 PM
