587,362 active members*
3,644 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > HEIDENHAIN > HEIDENHAIN -> GENERIC > Gross positioning error Y 1C (got error on both X/Y axis) after replaced spindle driv
Results 1 to 2 of 2
    Sep 2019
    11
    I'v had trouble running the spindle, and suspected a fault in my Spindle drive (indramat kda 3.2), but all axes have been working fine, I replaced the spindle drive and Indramat powersupply unit and powered up the machine again, but then I was only able to move the Z-axis, the X/Y axis give me this "Gross position error Y 1C) (for the Y axis).
    I thought it maybe was something else wrong with the spare drives, so I put back the "original" drives, but still get this error - so I suspect there might be something that needs to be "reset" or reloaded?
    Any tips would be appreciated - the spindle drive I'v moved the programming unit over between the units, as the spare drive was setup for a different motor.
    Was still no joy with the spindle on the spare drive either so any tips that might cause this behaviour is also appreciated (the spindle drives gives me N * NCMD "error code" when I try to run the spindle).
    The unit is a Heidenhain 407
    Sep 2019
    11
    Re: Gross positioning error Y 1C (got error on both X/Y axis) after replaced spindle
    Just thought I'd give a small feedback on this one, as it turned out to be due to some loose connection on the DC rail going to the XYZ axis drivers......just for reference
