Hello Wheatie:
Wow: Thanks for the super response. I am hoping to get it to run with the stock leadscrews but am not sure what the repeatability will be that way. Thank you for the explicit information, I will use that to get ballpark pricing anyway. Pennies are not adding up very fast these days. If I may, I will contact you again if I have issues that I cannot solve. Only electrical question so far is do I or do I not connect 5vdc to the enable pin of my DQ542MA Drivers. I have seen information that does it both ways. Would like to be able to disable the drivers individually if necessary by using a switch in the enable line. Anyway, thanks again and take care.
Burt
